Structure "copy samples to local drive" grayed out
Hi All,
I'm really starting to like Structure, but I keep getting stuck about this issue. I couldn't find any reference to it in this forum, which really surprised me because my workflow is so common. I would usually build a Structure patch during a session, while connected to some Samples Drives, importing all kinds of samples and ending up using only a few. When I'm happy with the samples I chose to use, I want to save them to the session folder. There is a menu option called "Copy Samples to Local Drive" - but it's always grayed out no matter what I try )-: The only way I could actually select the "copy sample to local drive" command from the menu was in EDIT mode. However - it didn't do anything: No files were saved in my session folder, and Structure still referenced my samples drive. Does anybody here know about this issue? Am I overlooking something that's obvious? Thanks, ith |
Re: Structure "copy samples to local drive" grayed out
Hi
Same issue, same symptoms and results, advice appreciated. |
I think that function only works with patches/samples that are being accessed from on optical drive, i.e. CD/DVD.
PT 10.3.2 MIDI "Input devices" grayed out | tooold | macOS | 3 | 02-23-2013 12:30 PM |
Structure - what does "Monolithic" mean as it pertains to "part" files? | Jared_TL | Virtual Instruments | 2 | 12-07-2008 03:37 AM |
"Buss" and "Plug in" words grayed out... | amba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-10-2008 04:23 PM |
"Import Audio to track" grayed out | stretto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-04-2002 01:51 PM |
Samplecell II plus TDM "path n/a", grayed out | uptown | Digidesign Hardware & Software | 0 | 03-06-2002 07:24 AM |
