#131
Re: HEAT (Harmonically enhanced Algorithm Technology)
About the whole 64-bit, from my understanding the main benefit of having a full on 64-bit DAW is to incorporate more than 4GB or RAM.
I believe some DAW's are finding ways to maintain their DAW at 32-bit while still accessing beyond this RAM limitation. But don't ask me, I'm not a software engineer... |
#132
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
#133
- so this Heat thing made me wanna try to compare to Analog Channel...that one sounds great too when used in the same way as heat. Now, in order to control how much you gain all the channels overall you gotta of course group all channel or hit "all" in group and enable inserts...BUT, and this maybe be a bug in 8.1 cause I haven't tried it before...the stereo versions of the plug seem to work independently of the mono versions - is this correct ? shouldn't they all follow the one plugin you're tweaking ? in which case analog channel would be insanely cool actually...
heat is easy and sounds good, but I use a lot of VI's so I wanna hear mix mix closer to what it's gonna be |
#134
Assuming your concern is with tracking workflows, the safest bet is to stick with your "normal" workflow while tracking and track your VI parts first (without the added routing of Instrument-thru-Audio track) and once the VI part is down and you know the timing and feel are good you can setup the extra routing and get the HEAT sound on your VI (with ADC enabled, of course). In the most basic scenario of routing an Instrument track with a VI to an Audio track you'll be dealing with an extra 23 samples of latency which is less than 1ms, so not too bad. However, with ADC things can get fairly complicated with more complex routing, so I find it is usually best to keep the routing as simple as possible while tracking. Hopefully that answers your question. |
#135
#136
I hope the new engine in PT9 corrects for all of these scenarios, you should be able to solve the general case with a delay compensator. And it should always be on during tracking and mix alike. |
#137
Ok, so I have a proven workaround for printing HEAT to your Audio Tracks. This way you can benefit from the sonic imprint before mixing, or when mixing on LE systems. In my case, I DO mix on the airplane
I can hear it now, "yeah right! try doing it with 100-track count..." Nevertheless, it works. http://www.youtube.com/watch?v=f7W0UsAarvk -Wiz |
#138
does heat need an accel card to run on or will it run on the older non accel cards as well??
#139
This would also be a great way to use HEAT differently on each track. You can find the best setting for drums, print that, then move on to the Bass and so on.
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
#140
Interesting. I´m on 10.5.8 too. Runs as solid as 8.0.4?
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
Does comping to a Heat enabled track print the Heat? | joshdrucker | macOS | 0 | 03-12-2014 10:17 PM |
9.0.2 crashes when setting X-Form algorithm | A Chapman | macOS | 3 | 03-22-2011 08:38 AM |
Melodyne algorithm unhappiness thread | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-26-2009 02:28 PM |
Rhythmic algorithm | Steve MacMillan | Pro Tools TDM Systems (Mac) | 3 | 11-28-2007 10:44 AM |
positional scrubbing algorithm? | KingTor | Pro Tools TDM Systems (Mac) | 0 | 06-05-2000 01:04 PM |
