Old 02-27-2010, 04:15 PM
aftermid aftermid is offline
Default Service Pack 2 on TDM Mix
I'm currently using an Old TDM Mix system v6.4. I know that Digi didn't allow upgrading to Service pack 2, until the HD systems came out. I want to buy a software that requires Service pack 2 as a minimum, but I'm not sure if I do this, Protools will work on Service Pack 2. Has anyone been able to use Service pack 2 or higher on TDM mix 6.4 successfully?
Old 02-27-2010, 04:20 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Re: Service Pack 2 on TDM Mix
Someone else will probably chime with a more detailed response, but if I remember right there are several people on here running mix with xp SP2.... I believe SP3 is where the uncharted territory begins.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 02-27-2010, 06:13 PM
sunburst79 sunburst79 is offline
While I can't speak for TDM I've run a 001 on SP2 and SP3 in LE land with 6.4cs9 and cs6. It seems happy enough with 6.4.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-27-2010, 07:51 PM
yeah, I've seen that 001's and Mbox's are happy w/ the Service pk2, not sure about the TDM Mix stuff. By the way, have you per chance tried using your 001 or perhaps LE with the old TDM mix interfaces, like the 882's?
Old 02-27-2010, 08:18 PM
It won't work. The only thing that will connect to the digi 001 card is it's own breakout box. LE and TDM hardware are not interchangeable.
- John
Pro Tools 8 on XP Service Pack 2? Service Pack 3 registry issues? Infiltrator Pro Tools M-Powered (Win) 7 02-22-2011 12:18 PM
Service pack 3 and PT 8.0.4 keithaska 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-08-2010 05:51 PM
Windows XP Service Pack 1 or Service Pack 2 Does it matter? Billy57 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-27-2007 09:37 PM
PT7 with XP Service Pack 1 Mcgrathx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-30-2006 07:43 AM
XP 2 Service Pack stevegrisham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-01-2004 07:07 PM
