Turn off accent in Click Track plugin?
Is it possible NOT to have an accent when using the Click Track plugin? It lets you turn it down completely, but then you don't have that beat. Just want all the beats generated by the plugin to be the same. Thanks...
Re: Turn off accent in Click Track plugin?
if you set "accented" & "unaccented" to the same level your problem should be fixed!
Asus A4KA-Q003H AMD Ath 64 3200+ 1024MB WD Scorpio 60GB 2.5" PATA 5400 8MB davec 32+15 www.surely.nl |
THat is correct.
same DB = same output.
5198 Studios |
not true, some of the accents are a differnt pitch, you have to set the click to eight note something i'm not sure of the full name, but all of those have the same sound then you have to set them to the same level.
www.klarityrecordingstudios.com |
The MIDI click options of the program drive the click plug-in's accent notes. If you set the MIDI click options so that the accented note is the same note as the un-accented note, it should solve your problem.
Details in chapter 11 of the Reference guide in a section called "Recording with a click" and in Chapter 5 of the Digi-rack plug-ins guide.
Thx, guys. Confirmed you can't change the note in the ones that have a different note/tone. From the plugin guide:
Choose MIDI > Click Options and set the Click and Countoff options as desired. !!! - The Note, Velocity, Duration, and Output options in this dialog are for use with MIDI instrument-based clicks and do not affect the Click plug-in. |
So since the note option in that dialog has no effect on the click plugin how do you change the pitch of the accented note so that its the same as the unaccented notes in the plugin?
You have to choose one of the clicks that don't use a different note for the accent. I think cowbell is one of them.
Change Click Track Accent Note Position | music_al | Pro Tools 10 | 1 | 08-19-2012 01:05 PM |
click track and accent beats | wildplum | Tips & Tricks | 6 | 10-08-2009 03:07 PM |
Is It Possible to make CLICK Plugin with no accent in LE? | doubtful guest | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-28-2008 06:19 PM |
Click Track - How to "UN" accent the click plugin | pepperbox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-02-2006 06:37 AM |
How do turn a click track inti a grid | centerstage | Tips & Tricks | 2 | 04-23-2005 10:23 AM |
