  #31
Old 01-20-2020, 05:37 AM
basehead617 basehead617 is offline
Default Re: NAMM new HDX or nothing!!!
Have something in mind? DSP version of AAX can be developed with same SDK than its native version, just that DSP has limitations that the developer need to be able to overcome. Developers don't like limitations, but that is just the nature of DSP.
I don’t know the technical details, just that people like the guy from Fabfilter have explicitly complained about the limitations and that it’s why they don’t have a DSP version.
I’m pretty sure everybody that makes AAX would release them as AAX DSP too if it was just as easy.
  #32
Old 01-20-2020, 06:01 AM
JFreak JFreak is online now
I’m pretty sure everybody that makes AAX would make AAX DSP if it was just as easy.
There is 16MB ram per chip for starters, maybe just need more and no go.
  #33
Old 01-20-2020, 12:56 PM
corp corp is offline
Hence, time for new cards.....
Still running older Macs with older PTHD...... purchased a new MP7.1 and presently debating on old HDX. Not waiting another year or two, three... for Avid. I would of thought that Apple announcing the new release years ago that Avid would of started on some type of update/upgrade when the new MP releases but nope....Avid behind the ball as usual. MTRX Studio, another HDX card carrier..... Just sell the company.
  #34
Old 01-20-2020, 04:25 PM
Why would you install 6 cards if you got the same out of 3 cards? Of course people are expecting that technology moves forward. HDX is +8 years already.
For comparison, Original HD cards only lived 2 years until there was HD|accel, and another 2 years and the HD Core card got a speedbump in its PCI-e incarnation. Generation before that (MIX) only lived 4 years. Original TDM cards lived 4 years before that.
So yes, card upgrade is way overdue.
Bingo
I heard a rumor that maybe Steinberg might introduce a PCIe card.....would be interesting.
  #35
Old 01-20-2020, 07:41 PM
LDS LDS is offline
If that is the case, Avid must have really borked the implementation of AAX-DSP given the number of TDM plugins that never made it to HDX.
littledevilstudios.com.au
Pro Tools Ultimate 2019.6. OSX 10.14.6. HDX. Avid Omni. MacBook Pro 2018. 6 Core i7. 32Gb. 4x mSata SSD Drives + 4x HDD. Blackmagic Intensity PCIe. ATI RX580. Sync HD
  #36
Old 01-20-2020, 07:45 PM
I'm not a DSP programmer but, I imagine it's as much market forces at work, as the nature of the industry has changed (and native has become much more powerful than it was at the time of TDM's introduction). I suspect Avid would have actively had to subsidise developers to make AAX DSP plugins – and I wish they did, in which case I would be contemplating buying another HDX card rather than a UAD Octo. Instead, pushing the voice count at high sample rates is the only thing that would make me consider adding another card.
  #37
Old 01-20-2020, 07:46 PM
Back in the day, there was no alternative. TDM is what you did if you wanted to do business. Now there are alternatives in the Native-land, so DSP plugins are not a necessity for plugin vendors anymore.
From what I have read and heard, coding AAX-DSP (with C++) is a whole lot easier than coding TDM (with assembly). But the nature of DSP as a restrictive platform never goes away.
Real problem here is Waves screwed DSP business by dropping DSP development and therefore DSP plugin prices by 50%, or in other words, today plugin vendor cannot double the price when they have DSP available.
  #38
Old 01-21-2020, 05:35 AM
Here’s an idea given Avid seems to be OEM’ing a lot of hardware these days. License the UAD cards and put a TDM bus connector on them. Instant plugin ecosystem and low latency (because it would avoid round-tripping to the CPU). They can still sell you a HDX card to run the mixer and other AAX DSP plugins.
  #39
Old 01-21-2020, 06:51 AM
RyanC RyanC is offline
If it was going to interest me, they need a new DSP system where the standard SDK developed plugins don't have 34 samples of latency or more.
I don't know that much about DSP, but if two (quality) inserts have more latency than the 32 sample buffer, then the money is better spent on a faster computer for my workflow.
Make a new card with more power, get someone like Bricasti to make a high end verb for it, something that wouldn't be practical in native land, get the latencies down to below what can be done with native...In other words make something to where there is an actual advantage to having the DSP.
Otherwise put a fork in it, put the resources into developing a better audio engine, add 2x and 4x buffer settings for VI's and develop some native hardware that is at least as good (if not better than) other companies.
  #40
Old 01-21-2020, 07:00 AM
It all comes down to how far the developer wants to tune the plugin. Avid "standard" latency is 10 samples, and more if the algorithm needs that (f.ex Pro Subharmonic 394 samples).
Don't know why the new DSP is "slower" than TDM, which had 4 samples "standard" latency. For comparison ReVibe TDM had 4 sample latency but ReVibe AAXDSP has 66 sample latency. There must be some timing issue with how AAXDSP addresses its memory, compared to TDM. Only explanation I can come up with.
Theoretically you always need one sample for reading in, one sample for processing, one sample for writing out. So those old 4 sample TDM plugs were pretty damn awesome -- only one sample shy from perfect.
So yes, AAX-DSP XL or whatever it would be called is way overdue. I cannot see myself putting my money into these +8 year old cards today because either the cards are going to be updated or going away soon, and neither scenario encourages me to invest.
11R at NAMM musicman691 Eleven Rack 35 02-18-2013 03:37 PM
Namm broken81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-11-2010 12:51 PM
NAMM 07 MiamiMusicMan Virtual Instruments 3 01-18-2007 10:50 AM
NAMM '07 - What do you want? dts.music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 26 01-16-2007 03:40 AM
