Old 01-21-2006, 03:52 PM
Ray Fabi Ray Fabi is offline
Default Inspector XL (meter)
Hi, I'm considering the Inspector XL meter software (now that RTAS can be used on AUX with PT7), I was wondering if anyone had experience with it? Tried the demo, and it seemed to work fine, but sometimes, my spacebar would not work... Is this a known glitch, or ... just my system?
Thanx
Ray Fabi
Virus Music
Ton of Bricks Studios Montreal
514-990-2713
www.fabi.com
Old 01-21-2006, 04:32 PM
hmorovic hmorovic is offline
Default Re: Inspector XL (meter)
I've been using it since august and had no problems at all, only it is is a kind of cpu eater, but if you have enough power in your computer,you should be ok... oh, and i love it, very, very useful!
Hope this helps!
H.
002 - MacBook Pro i7 2.0 GHz, 8 Gb RAM
OS 10.9.5, PT 10.3.10 - Mallet KAT Pro
moromusik.com
Old 01-21-2006, 07:01 PM
tamtamstudio tamtamstudio is offline
I've got here and I love it.
On G4, Inspector XL is very hungry and sometimes (very often) glitches.
Corrado Magalotti
Tam Tam Recording studio
Old 01-28-2006, 05:20 PM
On a Dual 2.0 G5 (2.5 G Ram) running Tiger, HDAccel system with four 192's, Inspector XL on my Master Fader, right after my final limiter, it glitches, it creates small "pops" every so often... If I disable or remove it, problem goes away. I'm waiting for a word from the company, but right now, unusable, although I just purchased it, three days ago...
Ray Fabi
Virus Music
514-990-2713
www.fabi.com
Old 01-28-2006, 05:26 PM
What's your H/W Buffer size set to?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-28-2006, 05:53 PM
myke2242's Avatar
myke2242 myke2242 is offline
I have it too. great plugin but. there is a issue with the amount of sample delay this can cause. I see a delay of 4100 samples when inserted!!!
_____________________
HerronSFX.com
Herronsound.com/blog/
HerronSFX Instagram
Old 01-28-2006, 05:57 PM
jeremyroberts jeremyroberts is offline
IXL is great. However, it is NOT yet optimized for PT7 -- so, for best results, make sure you are ruinning on only single processor. Also, crank up your hardware buffer - at least 512, if not more.
It is a comprehensive product with many variables... and you don't have to run the cpu-hog multi, you can run just the meters or just the spectrum, etc...
I've been very happy with the K-metering system. For $89, it's practically a no-brainer.
--Jeremy
Old 01-28-2006, 08:19 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
It's not the buffer size.
EAS has acknowledged a problem with CPU spikes on PT7. They wrote me a while back with a fix in the works.
IMDB
Old 01-31-2006, 09:23 AM
Hi, my buffer size is set at 256 samples, Level 2 (DAE Playback Buffer)...
So, it might be a known bug. Good, at least they are aware of it, and hopefully will fix it.
thanx
Ray Fabi
Virus Music
514-990-2713
www.fabi.com
OT: Replacement for Inspector XL! vocalvoodoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-13-2006 12:16 PM
EAS Inspector XL update to 1.0.2... Ducky General Discussion 1 02-23-2006 01:06 PM
there's a new Inspector XL 1.0.2 minister Pro Tools TDM Systems (Mac) 2 02-21-2006 06:10 PM
Inspector XL filosofem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-03-2005 05:54 PM
Inspector XL geitz Pro Tools TDM Systems (Mac) 3 12-03-2005 04:40 PM
