Soop up the Mix System
Damn
I cant afford the upgrade to HD until I sell yet but I have some money to upgrade my system. I curently have a G4 Dual 1.25 Mix Referb Core Card, an Adat Bridge 24 and an Octopre with adat card. I'm seeing that on ebay I may be able to get a mix farm card under $1000 USA 1. What Converters would you sugest I get for extra inputs? 2. What do you all use as a volume controller. 3. Any one with Mix+ is it enought for Pop music production or is mix 3 the way to go. Rock on Kitch |
Re: Soop up the Mix System
I think that Mix + would be enough, but you never want to be out of processing power in a session. As for the extra in's and outs, the 888|24 is the only way to go on a Mix system.
Dont forget that going from a mix+ to a mix3 doesnt get you any more tracks, 64 is max, but it will get you more plugins...
Yep I know. I'm prety happy with 64 tracks at present.
Any other converters that you would suggest? |
If you are looking for extra ins and outs you should not go for the 888. Using your ADAT bridge you could get an RME ADI8 second hand. They are the best cheaper converter around and the clocking is quite stable.
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 |
Mix farms seem to be going for around $1300 so i don't see where you can get them for under $1k.
search for completed items on ebay to see actual selling prices. They are indeed sometimes going below 1000, although the true range is 1000-1200.
been using mix+ with an xtra old dsp-farm for years....
maybe for producingbut it is NOT enough for mixing (and i've got loads of outboard) just got an hd2 and i'm using the rme for monitoring/mastering. it is 1500% better than the 888/24!! |
I would also suggest looking into Apogee hardware. It's definetly a step up.
My System is: Mac Pro 3.2GHz 6 Core 32GB RAM 1- HDX 1 - Apogee Symphony Mk2 8x8 1 - HD 16x16 Interface MOTU MTP/AV ------------------------------ Second System Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2 32GB RAM 1 - HDX 1 - Avid Thunderbolt 3 Expansion Chassis 1 - HD 8X8 Interface MARVINBASS Digital Audio, LLC Ex PT Beta Tester Woodland Hills, CA. |
System Requirements and full System Setup | MadDogRunner | Windows | 2 | 02-25-2013 05:44 PM |
D-Show system with power sequencer/relay system. | TheatreWeasel | VENUE Live Sound Systems | 2 | 01-15-2012 03:35 PM |
Good System Usage/RTAS settings for Quad Core system | Mental Clarity | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-19-2008 03:09 PM |
Fat 32 IDE rmoveable drives (from WIN98SE system) not accessable from XP system | steve at Your Heaven | Pro Tools TDM Systems (Win) | 7 | 06-12-2003 12:17 AM |
New Allenstein system.... Radeon 7500 causes system to lock up.. | Siberian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 03-09-2003 07:23 PM |
