Old 07-08-2013, 05:55 AM
Pete Gates Pete Gates is offline
Default New workspace problems
PT 11.0.1HD
Trying to do the old sort by Path in workspace to find files that aren't in the current project's Audio Files folder (about time there was a better way of doing this but anyway..). It doesn't sort properly, I'm finding odd files that are out of order. Big problem for me as I'm often referring to massive Rushes folders that I want to dump 99% of.
Also, even when I've found the foreign files "copy and relink" doesn't seem to be working properly. It seems to copy it across but it won't relink it. I'm doing some more checking but beware. The second time I did a copy I got a very odd message on the left "The Following Plug-ins have a missing digital signature and will fail to load in the final candidate build" and the expected message in the right "target directory already exists". Just tried looking again in the Audio Files folder and PT won't see that file there (it is). Also, if I 'filter' the workspace window so I can see the file I want to copy and relink, "copy and relink" is not available in the right click menu. I don't know if that was always the case with filtering down the set (I'll look in 10 later) but that's pretty useless.
Pete
Old 07-09-2013, 04:47 PM
PaulV's Avatar
PaulV PaulV is offline
Default Re: New workspace problems
Hi Pete,
Sorry you're running into this issue. We are aware of the bug, and are working on a fix for it for a subsequent release.
Cheers,
Paul Vercellotti
Avid Engineering
Old 07-10-2013, 11:27 AM
Thanks Paul,
You guys have done brilliantly with this release, there were bound to be a few little things to resolve. Just a couple of things need to come into place for me to be able to use it exclusively.
Pete
Problems with the workspace window markatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-27-2010 01:54 AM
Problems with Workspace Browser in PT 8 Rockfool 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-13-2009 05:35 AM
Workspace problems and firewire weirdness fasttraxx Pro Tools TDM Systems (Mac) 10 08-07-2008 11:37 PM
Workspace Problems (X2) Help! dacapo Pro Tools TDM Systems (Mac) 1 08-21-2007 03:27 PM
Problems with workspace waveforms! Please help!!! arturix Pro Tools TDM Systems (Mac) 5 08-03-2007 02:17 AM
