Old 05-22-2012, 12:10 PM
the glass is half empty the glass is half empty is offline
Default 10.2 mutes after bounce
I updated my HDX system to 10.2 and now after I bounce a file, outputs 1-2 become muted. If I change the output to "no output" and then back to "1-2", audio is no longer muted. Is anyone else experiencing this?
Old 05-23-2012, 12:30 PM
PaulV's Avatar
PaulV PaulV is offline
Default Re: 10.2 mutes after bounce
Hi there,
Does this happen every time with a particular session? If so, would you mind sending it in to ProTools_Transfer at avid dot com?
Do you have any mute automation on that output perchance?
Cheers,
Paul Vercellotti
Avid Engineering
Old 05-24-2012, 12:44 PM
I emailed you a session file. Since I emailed it I also discovered that to unmute I simply have to click on the master fader and voila, audio.
Old 05-25-2012, 03:36 PM
PaulV's Avatar
Can you double check that e-mail? It didn't arrive.
Also, you don't need to include audio, just the session file. If it was too big, that might be why it didn't make it.
It sounds like the issue is pretty repeatable?
Cheers,
Paul Vercellotti
Avid Engineering
Old 05-25-2012, 03:43 PM
I didn't have the underscore in the address. I resent it now. It is easily repeatable.
11r mutes randomly jpeltsi Eleven Rack 3 03-09-2012 11:11 AM
mutes - which daw has it right? musicman691 General Discussion 2 01-28-2012 02:24 PM
Is there a way to link track mutes to send mutes? Ed Douglas Tips & Tricks 6 01-05-2010 06:39 PM
Send Mutes to Follow Channel Mutes Jeff E Pro Tools TDM Systems (Mac) 8 08-31-2009 08:05 AM
AES Mutes james tebb VENUE Live Sound Systems 1 03-19-2009 07:12 PM
