Old 05-22-2012, 04:50 AM
David Johansen David Johansen is offline
Default "Problem detected with the audio clock" HDX
Hey guys!
Im still having big problems with the HDX system. The main problem is a periodic message saying "Problem detected with the audio clock" when launching sessions. This error stops the entire session from playing.
After updating to 10.1.3 the message are coming more often to the point that I really can't get any work done.
After restarting , reflashing and prefsthrowing everything might work flawlessly until I open another session . Then I have to do this hole procedure again.
I have just a Avid HD (888config) connected and no external clock of any kind. Everything running on internal and just analog api and neve preamps connected .
Setup is :
Mac Pro 3.33 GHZ 6 core Intel Xeon 24GB 1333 Mhz DDR3 ram
OS 10.7.3
HDX1 and Avid I/O
Pro tools 10.1.3
Old 05-22-2012, 09:03 AM
PaulV's Avatar
PaulV PaulV is offline
Default Re: "Problem detected with the audio clock" HDX
Hi there,
We've fixed several HDX clock issues with 10.2. I'd recommend you try this version.
Cheers,
Paul Vercellotti
Avid Engineering
Old 06-01-2012, 05:48 AM
umalight umalight is offline
Originally Posted by PaulV View Post
Hi there,
I have this problem also. Updated to 10.2. Not better. I also get some typical "clicks" from clock issues, although I'm on internal clock...
"Problem detected with audio clock. Check audio clock and sample rate." Focusrite 2i4 Terry Wetzel Third Party Interfaces 10 11-08-2013 06:18 AM
Please help - "Problem detected with audio clock" error on HP laptop NickPt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-28-2011 05:49 PM
"problem detected with audio clock" error turbodude Pro Tools M-Powered (Win) 0 03-10-2011 01:01 PM
"Problem with audio clock detected." error; Pro Tools won't start playback wintersdark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-04-2010 06:23 PM
"Problem detected with audio clock" on brand new installation Katzi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-18-2010 12:10 PM
