Old 03-17-2012, 05:35 PM
funkymik111 funkymik111 is offline
Default HELP please PT 10.1.1 suddenly QUITS
Hi...
DOES ANYBODY KNOWS WHAT THIS MEANS??
Process: Pro Tools [222]
Path: /Applications/Avid/*/Pro Tools.app/Contents/MacOS/Pro Tools
Identifier: com.digidesign.ProTools
Version: 10.1.1.33 (10.1.1f33)
Build Info: Unknown-1011033~33
Code Type: X86 (Native)
Parent Process: launchd [149]
Date/Time: 2012-03-18 01:17:53.287 +0100
OS Version: Mac OS X 10.7.3 (11D50d)
Report Version: 9
Interval Since Last Report: 669150 sec
Crashes Since Last Report: 22
Per-App Interval Since Last Report: 41810 sec
Per-App Crashes Since Last Report: 3
Anonymous UUID: 92CB163F-C3A1-4197-B111-228D52FB078E
Crashed Thread: 15
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000005adf7000
VM Regions Near 0x5adf7000:
MALLOC_LARGE 000000005adad000-000000005adf7000 [ 296K] rw-/rwx SM=PRV
MALLOC_TINY 000000005ae00000-000000005af00000 [ 1024K] rw-/rwx SM=COW
Application Specific Information:
objc[222]: garbage collection is OFF
Thread 15 Crashed:
0 com.digidesign.plugin.ElasticAudio 0x344230a0 CSolaProcessElastic::FillFadeInGrainHolder(CSolaPr ocessElastic::ContextState&, int, double) + 784
1 com.digidesign.plugin.ElasticAudio 0x34424f5b CSolaProcessElastic::PrepareNextSegment(CSolaProce ssElastic::ContextState&, long) + 2587
2 com.digidesign.plugin.ElasticAudio 0x34425cf1 CSolaProcessElastic::Process() + 2257
3 com.digidesign.framework.DAE 0x03f2a6c5 CFicElasticCFMPlugIn::Process() + 21
4 com.digidesign.framework.DAE 0x03f2ce88 CFicElasticRenderer::RenderARegion(DSK_BoundedRegi on&, Cmn_PolyVector<float*, false>&, unsigned long, unsigned long, DSK_VTemporaryAllocator*, DSK_VRegionReader*, DSK_ParsedZone&, unsigned long, bool) + 760
5 com.digidesign.framework.DSK 0x052dd50d DSK_RegionPlayer::Play(DSK_BoundedRegion&, DSK_VTemporaryAllocator*, DSK_CRegionReader*, DSK_ParsedZone&, Cmn_PolyVector<float*, false> const&, unsigned long, Cmn_PolyVector<float*, false> const&, bool, unsigned long&, unsigned long&) + 301
6 com.digidesign.framework.DSK 0x052d0ba0 DSK_ChannelPlayer::TryToPlayRegion(DSK_RegionPosit ion const&, DSK_BoundedRegion&, DSK_VTemporaryAllocator*, DSK_CRegionReader*, DSK_ParsedZone&, bool&, unsigned long&, unsigned long&, unsigned long&) + 688
7 com.digidesign.framework.DSK 0x052d1bdc DSK_ChannelPlayer::PlayRegions(std::map<DSK_Region Position, DSK_BoundedRegion, std::less<DSK_RegionPosition>, Sys_AtomicSTLAllocator<std:air<DSK_RegionPositio n const, DSK_BoundedRegion> > >&, DSK_VTemporaryAllocator*, DSK_CRegionReader*, DSK_ParsedZone&, long long) + 668
8 com.digidesign.framework.DSK 0x052d2fd4 DSK_ChannelPlayer:oSomeWork(DSK_VTemporaryAlloca tor*, DSK_CRegionReader*, long long, long long*) + 1188
9 com.digidesign.framework.DSK 0x052dac9c DSK_PlayerEngine:oSomeWorkCommon(DSK_VTemporaryA llocator*, DSK_CRegionReader*, long long*) + 124
10 com.digidesign.framework.DSK 0x052db791 DSK_PlayerEngine:oSomeWorkFromThread(long, long long*) + 145
11 com.digidesign.framework.DSK 0x052db955 DSK_PlayerEngine::CWorker::ThreadMain() + 53
12 com.digidesign.framework.CoreFoundation 0x00375734 Sys_RawThreadTask::Run() + 36
13 com.digidesign.framework.CoreFoundation 0x003922d4 Sys_RawThread::ThreadIDsAreEqual(void*, void*) + 68
14 com.digidesign.framework.PlatformSupport 0x035de2d7 CTask_Imp::MacOSXMasterThreadProc(void*) + 121
15 libsystem_c.dylib 0x911e9ed9 _pthread_start + 335
16 libsystem_c.dylib 0x911ed6de thread_start + 34
Thread 15 crashed with X86 Thread State (32-bit):
eax: 0x5adf6ffc ebx: 0x34422da1 ecx: 0x00000000 edx: 0x004443b6
edi: 0x004443b6 esi: 0x5bf03400 ebp: 0xb08b1498 esp: 0xb08b1370
ss: 0x00000023 efl: 0x00010202 eip: 0x344230a0 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000023 gs: 0x0000000f
cr2: 0x5adf7000
Logical CPU: 0
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 19
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 310
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=518.0M resident=368.0M(71%) swapped_out_or_unallocated=150.1M(29%)
Writable regions: Total=1.7G written=720.6M(40%) resident=1.2G(71%) swapped_out=0K(0%) unallocated=516.5M(29%)
REGION TYPE VIRTUAL
ATS (font support) 32.8M
CG backing stores 137.7M
CG image 48K
CG raster data 128K
CG shared images 3408K
CoreAnimation 28.4M
CoreGraphics 8K
CoreImage 4K
CoreServices 1680K
IOKit 24.8M
IOKit (reserved) 17.6M reserved VM address space (unallocated)
MALLOC 1.1G
MALLOC guard page 32K
MALLOC_LARGE (reserved) 99.7M reserved VM address space (unallocated)
Mach message 24K
Memory tag=240 4K
Memory tag=242 12K
Memory tag=249 696K
OpenCL 28K
OpenGL GLSL 1116K
OpenGL GLSL (reserved) 128K reserved VM address space (unallocated)
PREINIT 48K
Stack 119.4M
VM_ALLOCATE 299.9M
__CI_BITMAP 80K
__DATA 101.9M
__DATA/__OBJC 460K
__FSSAP 20.0M
__IMAGE 528K
__IMPORT 544K
__LINKEDIT 120.0M
__OBJC 2876K
__OBJC/__DATA 44K
__PAGEZERO 4K
__PDSIG 884K
__POVERD 56K
__POVERT 56K
__RC_CAMERAS 232K
__TEXT 423.8M
__UNICODE 544K
mapped file 191.3M
shared memory 3764K
shared pmap 4724K
TOTAL 2.7G
TOTAL, minus reserved VM space 2.6G
Model: MacPro5,1, BootROM MP51.007F.B03, 12 processors, 6-Core Intel Xeon, 2.93 GHz, 24 GB, SMC 1.39f11
Graphics: ATI Radeon HD 5770, ATI Radeon HD 5770, PCIe, 1024 MB
Memory Module: DIMM 1, 4 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333531553742465238432D48392020
Memory Module: DIMM 2, 4 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333531553742465238432D48392020
Memory Module: DIMM 3, 4 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333531553742465238432D48392020
Memory Module: DIMM 5, 4 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333531553742465238432D48392020
Memory Module: DIMM 6, 4 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333531553742465238432D48392020
Memory Module: DIMM 7, 4 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333531553742465238432D48392020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.100.98.75.19)
Bluetooth: Version 4.0.3f12, 2 service, 11 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: Universal Audio UAD-2 Quad, sppci_othermultimedia, Slot-3
PCI Card: ATI Radeon HD 5770, sppci_displaycontroller, Slot-1
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@8,4,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@8,5,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@9,4,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@9,5,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@10,4,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@10,5,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@11,4,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@11,5,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@12,4,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@12,5,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@12,6,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@12,7,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@12,8,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@12,9,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@12,10,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@12,11,0
PCI Card: pci1057,3410, sppci_othermultimedia, Slot-2@12,12,0
Serial ATA Device: HL-DT-ST DVD-RW GH61N, 7,53 GB
Serial ATA Device: APPLE SSD TS512C, 500,28 GB
Serial ATA Device: SAMSUNG HD203WI, 2 TB
Serial ATA Device: Hitachi HDS722020ALA330, 2 TB
USB Device: hub_device, 0x0409 (NEC Corporation), 0x005a, 0xfa200000 / 2
USB Device: hub_device, apple_vendor_id, 0x9130, 0xfa240000 / 3
USB Device: Apple Cinema Display, apple_vendor_id, 0x9222, 0xfa242000 / 4
USB Device: hub_device, 0x0409 (NEC Corporation), 0x005a, 0xfd300000 / 2
USB Device: hub_device, 0x0409 (NEC Corporation), 0x005a, 0xfd340000 / 3
USB Device: hub_device, apple_vendor_id, 0x912f, 0xfd344000 / 4
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd344100 / 7
USB Device: ShuttlePRO v2, 0x0b33 (Contour Design, Inc.), 0x0030, 0xfd344130 / 9
USB Device: Apple Keyboard, apple_vendor_id, 0x0221, 0xfd344120 / 8
USB Device: USB Trackball, 0x046d (Logitech Inc.), 0xc408, 0xfd344300 / 6
USB Device: Apple Cinema HD Display, apple_vendor_id, 0x9221, 0xfd344200 / 5
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x5a100000 / 2
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0x5a110000 / 3
USB Device: iLok, 0x088e, 0x5036, 0x3a200000 / 2
USB Device: hub_device, 0x0451 (Texas Instruments), 0x1446, 0x1d100000 / 2
USB Device: USB-Chip, 0x0e50, 0x0002, 0x1d130000 / 6
USB Device: iLok, 0x088e, 0x5036, 0x1d120000 / 5
USB Device: iLok, 0x088e, 0x5036, 0x1d140000 / 4
USB Device: ProtectExecuter, 0x0819, 0x0101, 0x1d110000 / 3
FireWire Device: built-in_hub, 800mbit_speed
MAC PRO 2x2,93 Ghz 6 core Intel Xeon / SSD 500 Sys HD
24 Gb 1333 Mgh DDR3
PROTOOLS 10.0.1
OSX LION 10.7.3
Old 03-17-2012, 10:51 PM
PaulV's Avatar
PaulV PaulV is offline
Default Re: HELP please PT 10.1.1 suddenly QUITS
Sorry you're crashing, and thanks for posting the crash log. It seems to be a crash in the Monophonic Elastic Audio plug-in during playback. Does it happen every time you play this session?
If so, could you try a couple things so we can try to fix the crash? We'd like you to narrow down what part of the session causes the crash and e-mail it to us if you don't mind.
  1. Make a backup copy of your session
  2. Delete all the tracks except for the ones with Monophonic on them
  3. Save, the hit play and check if the crash still happens
  4. If yes, reopen PT and try to find out which regions on the timeline cause it
  5. When you have a small session that still crashes, do a Select Unused in the Clip list, and remove those regions from the session (don't delete the audio files!).
  6. Then do a Save Copy In... to a new folder, and choose to copy all audio. It should only copy the parts used on the timeline.
Compress that folder and e-mail it to protools_transfer at avid.com
Hopefully we can fix this for you.
Cheers,
Paul Vercellotti
Avid Engineering
Inputs suddenly gone. Dodraugen macOS 0 05-09-2012 07:38 AM
Pro Tools 9 wont start! Quits unexpectedly.... Quits during startup... dbC4G Pro Tools 9 11 03-09-2012 07:23 AM
VIs - Output suddenly quits Shanegrla Virtual Instruments 13 02-22-2012 07:11 PM
suddenly getting quits due to rewire crizdee Pro Tools TDM Systems (Mac) 0 10-08-2011 03:29 AM
PT LE 7.4 suddenly quits geosel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-15-2010 05:36 PM
