Old 02-15-2012, 11:52 AM
Brian in Charlotte Brian in Charlotte is offline
Default Re: Avid - fix the redraw issue
No all my Pencil work is done either in Slip or Shuffle mode. I just finished up an editing session for some voiceover work I did - had the problem twice in about 15 minutes. But, as I mentioned before, if I process the file in some way, whether that be via Consolidate etc, the problem is fixed for that clip.
Brian on the Florida Suncoast
TheVoiceofBrian.com
iMac 5K 4.0GHz i7 Quad-Core, 24Gigs RAM, Radeon M295X, 1TB SSD, ThunderBay 4 w/2TBSSD, ThunderDock, OS 10.14.4, ProTools 2020, Avalon M5, Focusrite Clarett2Pre, Sennheiser 416,
Old 02-15-2012, 01:32 PM
tj_davies tj_davies is offline
This bug is 100% reproducable.
- Lower a clip's clip gain by 6db.
- Pencil a straight line below zero.
- Notice the line will be further below zero than where you actually drew it.
- Reverse the effect if you raise the clip's gain.
Check this:
http://duc.avid.com/showthread.php?t...ip+gain+pencil
http://protools.ideascale.com/a/dtd/...bug/86210-3779
So we're not talking about if there s a bug. There is a flipping annoying bug, which I ran into again today on a 50min show dialog editing. Luckily my workaround with the mentioned keyboard shortcut makes it halfway decent to work.
Timothy
G5 10.13.6
PT Ultimate 2019.12.0
www.pearls-music.com
Old 02-24-2012, 07:49 AM
Once again, I was pressed for time yesterday with an edit and this inexcusable Pencil Redraw issue seriously impeded my progress and caused much frustration. THIS is why people have such a problem with AVID - they simply are too slow to act and take a month of Sunday's to catch up with new OS releases. How I wish I was not running ProTools.
TheVoiceofBrian.com
Old 02-25-2012, 08:49 AM
AVID......why so silent on this? Spent nearly half my day editing dialogue and the Pencil Redraw issue was infuriating. To pay this kind of money for PT10 and have you folks drag your feet like this is horrendous. Most of us would go out of business if we operated like this.
TheVoiceofBrian.com
Old 02-25-2012, 03:33 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Originally Posted by blairl View Post
Under what conditions is this happening?
I have used the pencil tool to draw out clicks well over a thousand times since upgrading to PT 10. I have never seen the issue you describe.
Pencil tool is a destructive tool, so it re-writes the root audio file. Clip Gain creates a new clip every time you use it, and is a non destructive process. When you use the pencil tool on clip gained clips, the small portion you've edited reverts to 0 clip gain, and things get ugly from there.
Its a clash between Destructive and non Destructive waveform changes.
5,1 Mac Pro Dual Hex Westermere 3.6Ghz, 24gig Ram, Pro Tools HD Native 2020.3.0, High Sierra, Blackmagic Decklink HD Extreme 3D.
Old 02-25-2012, 03:46 PM
BobbyDazzler, so if I turn off ClipGain I should be able to workaround this?
TheVoiceofBrian.com
Old 02-26-2012, 01:58 AM
If you use the pencil on a clip with 0 clip gain, it will work fine.
Old 02-26-2012, 08:20 PM
PaulV's Avatar
PaulV PaulV is offline
Hi there,
Yeah that's an annoying one. Fortunately this has been fixed and will be in an upcoming PT release.
Cheers,
Paul Vercellotti
Avid Engineering
New Avid TC/E Plug-In issue... The Weed Pro Tools 11 2 12-24-2013 10:29 AM
AVID AAF import - automation issue David McCarthy Post - Surround - Video 1 02-11-2013 05:17 PM
Hardware Issue?? Avid Help! dhmusic Pro Tools TDM Systems (Mac) 0 12-30-2012 04:11 PM
PT8 wave redraw issue dkean 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-14-2009 01:40 PM
PTLE XP Redraw Issue? citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-20-2002 08:00 PM
