Machine Control installer
Hi
Anybody can help in finding Machine Control installer for 8.0.1 HD? Any help is greatly appreciated. Thanks |
Re: Machine Control installer
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) |
Great! Thank you!
another question just aroused.am i correct that to connect PT 10HD and 8HD via machine control i need 2 x sync io and keyspan adapter?
thanks! |
I am not certain I fully understand your question. Is your objective to lock two separate Pro Tools system together with MachineControl (9-pin)?
hi
yes exactly as you said) |
Each system needs a SYNC peripheral (I/O or HD). Each system needs a Keyspan adapter. Each system needs MachineControl. I think you need the black cable that came in the box for the MachineControl. The MachineControl box includes a cable for deck control (gray) and one for remote mode (black). I have never used MachineControl this way.
You ca use a standard 9 pin cable from Sync IO to Sync IO. If you are using Keyspans, then a 9 pin din to 9 pin din between the 2 adapters. The Keyspan was a workaround as many Sync IOs had 9 pin issues. You really don't need Sync IOs, if you just want to lock via LTC over serial.
IMDB |
Machine Control, no 9 pin Deck Control Section | uisdean.macleod | Pro Tools 10 | 1 | 06-25-2014 06:53 PM |
Machine Control BIG installer bug, wont start | rbhun | Windows | 10 | 02-11-2011 07:26 PM |
where's the Machine Control Installer? | EarHole | Post - Surround - Video | 4 | 10-14-2010 04:10 AM |
MIDI Machine Control out of control | zenbarai | Post - Surround - Video | 3 | 04-19-2002 07:08 AM |
Machine Control's supported machine | J. S. Bach | General Discussion | 0 | 01-17-2000 07:06 AM |
