Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Software (Win)
Old 03-05-2018, 04:50 PM
fahfah fahfah is offline
Default AMD Compatibility
I want to finally jump into Pro Tools.
I have an AMD FX 6100 Six-Core/3.3 Ghz machine running WIN10 Pro. Am I going to have compatibility problems?
Old 03-05-2018, 05:18 PM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
Default Re: AMD Compatibility
I am using an AMD rig to run Pro Tools with no problems. (see my signature). But note that I am using a very old version of PT. About all you can do is try. Make sure you do all of the optimizations in the Additional Resources link above.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Pro Tools LE 7.4cs10, Windows XP Home SP3, AMD Phenom II 1045T Processor, Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 03-05-2018, 06:45 PM
YYR123's Avatar
YYR123 YYR123 is offline
I had the FX 6800 (iirc) and never had an issue, i only used it for a short time - my main board was a Gigabyte with 3930k but i was build a hackintosh at the time, so I used the AMD while that was being built
Daniel
Old 03-06-2018, 01:56 PM
gcasper gcasper is offline
I know it's not the same architecture, but I'm running PT2018.1 in Win10Pro 64-bit on a Ryzen 1700 with no issues.
Ryzen 7 1700, ASRock x370 Taichi motherboard, 16gB 3200mhz memory, Windows 10 Pro, Digi002r, Control/24, Raven Mti2, Protools Native 10, 11, 12, & 2018.
Old 03-06-2018, 02:21 PM
YYR123's Avatar
You ought to start a thread with testing on this system.
Many people are/were interested in these CPU’s
I am curious what kind of performance you can achieve with it as well
Daniel
Compatibility between PT 10 and HD 9 Angelo.Farro Pro Tools 10 1 04-22-2012 11:21 AM
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade benosullivan Pro Tools 9 2 11-17-2010 12:05 PM
Mac HD1 Compatibility marclop Post - Surround - Video 5 10-19-2006 03:31 PM
Compatibility Pablo Andrés Digidesign Hardware & Software 0 11-05-2002 01:38 AM
PT HD compatibility Armando ICON & C|24 4 06-20-2002 06:50 PM
