Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 02-12-2018, 12:33 AM
jberguno jberguno is offline
Default 003 only shows 10 inputs and outputs
I'm running pt 12 on a 2017 mac book pro using usb c to thunderbolt to firewire 800. It works, but how can I get it to recognize all the inputs of the 003? I can use the 8 analog inputs on the 003 and 2 channels of S/PDIF
Old 02-12-2018, 01:00 AM
Sardi Sardi is offline
Default Re: 003 only shows 10 inputs and outputs
Have you get anything plugged into the ADAT expansion? If not, you’re not going to see any extra inputs.
Old 02-12-2018, 01:55 AM
No, I don't. So once I get an ADAT preamp and hook it up, it will show up?
Old 02-12-2018, 04:37 AM
Well, you need to explain what you mean by ‘show up’.
Are you talking about in the I/O tab?
Either way, you’re not going to be able to access those inputs if they don’t exist. =P
Old 02-12-2018, 05:27 AM
Sorry, Yes the I/O tab. I was able to hook up a friends a/d thru adat and the channels showed up.
Old 02-12-2018, 05:29 AM
In the I/O setup page on pt 12, how can I add mic preamps to the preamps tab?
Old 02-12-2018, 06:53 AM
you can’t unless you have midi controlled preamps. If you want to understand all this it is described in the Pro Tools Reference Guide. What problems are you having actually using the hardware?
Old 02-12-2018, 07:33 AM
ok. I wasn't having any problems. I was just curious as to why the adat inputs wouldn't show up. But it makes sense now that it will only show up if i have adat hooked up.
Old 02-12-2018, 09:56 AM
albee1952 albee1952 is online now
Things that matter for this:
#1-the session sample rate. the lightpipe in ADAT mode only operates at 44.1 and 48K(so the higher sample rates will not work thru ADAT optical).
#2-Hardware Setup>Optical Format; is it set to ADAT or SPDIF?
Assuming the session is 44.1 or 48K and Optical Format is set to ADAT, it might be as simple as hitting the DEFAULT button(Setup>IO>Input tab), or simply adding the paths and connecting via the grid
Saffire pro 40 shows only 1/2 outputs in PT 10 Flyingonempty Windows 6 09-01-2012 12:39 PM
switched to mbox pro > protools only shows inputs 1+2 keenast 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-14-2011 06:49 PM
003 factory shows only 4 interface inputs atskade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-11-2008 02:29 PM
I/O Setup shows only 2 inputs Ping Pong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-17-2004 04:25 PM
PT5.01 shows 1622 interface with 16 Outputs? Samhein Pro Tools TDM Systems (Mac) 6 09-19-2000 09:21 AM
