Old 03-16-2018, 04:54 PM
SamuelT SamuelT is offline
Default New to ProTools
Hello everyone, I've been an avid Cakewalk Sonar user and I've changed DAW teams. I upgraded to an iMac with 32 gigs and 2.0T hard drive. I have Protools and my Kontact loaded just fine. I need advice on what keyboard controller would be recommended since my Axiom 61 does not work other than the notes and modulation wheel. I'd to be able to control protools from a controller keyboard that will work with the system I have. Any recommendation?
Old 03-16-2018, 05:02 PM
BScout BScout is offline
Default Re: New to ProTools
It appears the Axiom 61 will work with Pro Tools. It just uses MMC and you need to set that up in ProTools Setup > Peripherals. Go and re-check your Axiom User manual for section 3.8.2
Pro Tools Ult 2018.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 03-16-2018, 05:07 PM
It works for playing but won't control sliders for organ vst or start and stop protools from the keyboard. Everything I've been able to research points to I need a newer keyboard controller. I want one I won't have to upgrade in the future.
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Pro Tools Software (Win) 0 08-25-2016 11:27 AM
Protools 8 m-powered unavailbe license after instal protools 11 Melle279 Pro Tools Software (Mac) 4 09-27-2014 08:05 AM
ProTools Shortcut keys suddenly became disabled in ProTools LE 8.0.5? jgbsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2011 01:08 AM
Sending protools projects to other protools users online kdtufan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2008 07:18 PM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
