Old 05-31-2018, 07:27 AM
its2loud its2loud is offline
Default Re: Izotope direct connect question
Originally Posted by musicman691 View Post
According to Izotope one needs to use the rx monitor plugin so one can hear the audio being worked on in rx
edit for additional:
See this: https://www.izotope.com/en/support/k...x-monitor.html
Only if you want to hear the audio through the DAW, like Pro Tools. You can use the computer systems audio output as well if you have the capability to switch or sum sources to your speakers. Ie computer output vs interface output.
Old 05-31-2018, 01:14 PM
If I'm working in PT (which is the whole thing behind using rx connect) then yes I'll want to hear things through it. What good is hearing something from a daw if you don't go through any plugin chain you might have after said track or clip?
Jack
QAPLA!
Old 05-31-2018, 07:21 PM
BScout BScout is offline
Because izotope RX is restoration/clean up software. Who cares what plugins it runs through before you render it (audiosuite) of if you send it out a separate audio interface?
You fix the audio then put it back on your track.
Pro Tools Ult 2018.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.12.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
HTML code is On
Izotope RX 5 Connect – 2 channels max at a time?? reichman Post - Surround - Video 2 09-03-2016 09:45 AM
2 Part Question: Direct Connect / Focusrite d2 Producers Never Sleep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-26-2002 11:55 PM
Question about Direct Connect support?!?!?! (re-titled) crs117 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-07-2002 05:23 PM
how-to Direct Connect peteri Pro Tools TDM Systems (Mac) 10 05-07-2002 01:11 AM
B4 Direct connect question Brickdog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-23-2001 01:22 AM
