  #131
Old 08-13-2018, 12:31 AM
krabbencutter krabbencutter is offline
Default Re: 2018.7 So Far...
Originally Posted by Philthy View Post
Well there's terrible news for a company shedding market share
You can expect many more companies to start dropping official Win7 support within the next 16 months. The extended support for Win7 ends in January 2020 and there will be no more security or bugfix updates by then. That doesn't mean Windows 7 or any software will stop working and many people will decide to keep running Win7 on an offline machine. But from a business perspective it will not be feasible to support an operating system that has officially reached EOL.
See https://support.microsoft.com/en-us/...cle-fact-sheet
  #132
Old 08-13-2018, 08:05 AM
xmission xmission is offline
Originally Posted by B.J. View Post
Win7 is not supported at 2018.7
Regards
B.J.
Yep. I found out the hard way Friday, when I tried to clear the problems by doing a fresh install. It wouldn't let me install 2018.*
I had to go back and incrementally install from 12.1 to get running again.
It would have been better for me to have had the window pop up when installing over an older version, and I wouldn't have been in a jam.
  #133
Old 08-13-2018, 08:30 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
I have three machines running 18.7 on Win7 with no issues. It's not "supported" basically means they wont test it. Doesn't mean it doesn't work.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
  #134
Old 08-13-2018, 10:19 AM
TNM TNM is offline
Originally Posted by Emi View Post
I repeat, @ 192 kHz sample rate. I could run at 128 (min. @ 192 kHz) but was unstable. 256 is stable @ 192 kHz, but for safety I left it at 512. Did I say @ 192 khz?!?
Divide to 4 the buffer size for 48khz behavior.
I repeat, that is completely normal and expected.
yes, i can read. 192.
256 is what's stable at 192 on my old crappy macs in sierra.
But I do my tests with 64 channels armed, each with effects.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
  #135
Old 08-13-2018, 03:33 PM
xrekcor's Avatar
xrekcor xrekcor is offline
hmmmm have to say I am still getting the buffer error, it seems to only happen after starting up PT and after loading a session I might get it just after the first run through, prolly about 2-3 times over the last week of several hours per day running PT. I have.... A) don't do anything - it hasn't appeared again even after hours of continuous working B) did try a testing lowering buffer after receiving the error prompt - still couldn't make the error reappear.
so don't know if its a biggy but hasn't seemed to have caused any grief here so not for me.
another weirder thing is and sorry this is slightly off topic..... a lil story I got hold an old Roland GP8 brought from the US a month or so back what a great lil unit btw, so once it got here I had it changed to Aussie power using a power board from another Aussie version. well the dang thing has been rebooting itself every few minutes to an hour or so (pain in da *ss dang thing) I have been going over it checking for dry solder joints (mine mostly) nothing seems to have fully fixed it until..... now I know us audio types can be very interesting individuals but I'm not too loopy to believe there is a connection. But!!!! ever since I updated to 2018.7 the ol GP8 has been running like a well oiled 1980's machine..... so just incase thanks for the fix Avid!!!!
ok back to the real world...
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
  #136
Old 08-13-2018, 04:14 PM
amagras amagras is offline
That happens to me when I try to run playback too quickly after the session has finished opening. Wait a few seconds before pressing space bar and see if that helps.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
  #137
Old 08-13-2018, 04:34 PM
xrekcor's Avatar
could be, ill take note of that when loading a session and see if there is any difference. for me PT throws the prompt a few seconds into the second play through and then doesn't throw it again even try to force it a lil. do you get it straight off or during the next play through?
thanks for your input. ill test over the next week and post a reply.
Rob
  #138
Old 08-13-2018, 05:14 PM
Maybe is one library that's still loading, that happened to me with MiniGrand, try deactivating one plugin at the time.
amagrasmusic.com
  #139
Old 08-14-2018, 02:29 AM
xrekcor's Avatar
the reality is its only happened 2-3 times since the update to 2018.7 and certainly over perhaps hundreds of cycles of a session(s) its not really an issue for me just that it popped up 2-3 times and thought I would mention it.
Rob
  #140
Old 08-14-2018, 11:18 AM
daeron80 daeron80 is offline
I'm encountering several bugs when working with MIDI tracks. The worst one is when a track is set to Clips, the Trim tool causes clips to shift down and to the right, making it impossible to see where you're trimming it to. Workaround is to select the point you want to trim to and use the keyboard shortcuts. Not a complete workflow killer. There are some other oddities that similarly have more-or-less acceptable workarounds. Overall, though, I'm loving the speed and stability. Retroactive is a godsend.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
OS 10.13.5 - will PT 2018.4 or .5 work well or stay with 2018.13? blankpro Pro Tools 2018 4 07-11-2018 07:22 PM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Upgrading from 2018.1 to 2018.3 with Application Manager lm183902 Pro Tools 2018 2 03-19-2018 04:41 PM
Reverting from 2018.3 to 2018.1 jamesleonard Pro Tools 2018 11 03-12-2018 05:21 AM
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 05:01 PM
