Old 12-23-1999, 04:33 AM
Stenjy Stenjy is offline
Default Correct ADAT sync mode and sample rate?
I made a mistake yesterday by ignoring the window that popped up and said, "The bit rate of the input does not match the bit rate of your session". My input was 48k optical from an ADAT but I guess my default setting on the 001 was 44.1. My question is, with ADAT tapes being tranferred that are 48k, should my hardware settings for the session be 48k and optical sync? My problem was that after recording this particular session, my mix would not play back or print to a CD (toast) at the correct playback speed. Am I making sense??? Any help would be appreciated.
www.earthtonesrecording.com
Old 12-23-1999, 10:01 AM
slinky slinky is offline
Default Re: Correct ADAT sync mode and sample rate?
when dumping ADAT tracks be sure the sample rates match and that optical is set to sync. before burning a cd you'll have to convert the mixed track to 44.1 khz.
Old 12-23-1999, 11:48 AM
lwilliam lwilliam is offline
OK, I did this once, too...(burned a CD from ADAT tracks without converting to 44.1).
The music was REAL SLOWWWW...
Larry W.
Larry
PTLE8/002r;OS 10.6.4 2 x 2.26Ghz quadcore,6GB RAM, Waves Platinum, many other plugins...
HD IO and ADAT sync at 192 sample rate? RTASW Pro Tools HDX & HD Native Systems (Mac) 1 08-03-2013 07:34 AM
Mbox Pro Sample Rate Selections Above 48 in Mode edshoe FireWire and USB Audio Interfaces (Win) 3 04-15-2013 04:01 PM
Pro tools could not set your audio device to the correct sample rate innermusic Pro Tools 10 4 05-06-2012 09:25 PM
002 not clocking to correct sample rate for itunes and quicktime goaler111 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-08-2009 08:36 AM
002 w Adat 96 KHz sample rate ??? robstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-03-2003 06:03 PM
