Old 10-29-2007, 07:46 AM
RynoRock RynoRock is offline
Default Digi 002: blank channel scribble strips after powering on
Hello fellow Digi 002 users. It appears that my 002 may have given up on me. After a couple months of non-use I powered it up and the channel scribble strips were blank on the 002 control surface. After turning it on and off a couple times, still no change. The next day I turned it on and it worked for a brief minute then went back to blank scribble stips and no response. My Powerbook G4 and Pro Tools LE 6.2.2 could not communicate with the control surface on account of this problem.
Anybody know if this is fixable?
Old 10-29-2007, 10:07 AM
DigiTechSupt's Avatar
Default Re: Digi 002: blank channel scribble strips after powering o
Contact Technical Support (650-731-6100) about this issue, and have the serial number of your unit available. It would also be best if you called while you have access to the 002.
Avid Audio Tech Support
Support FAQ
Flashing Scribble Strips Digi 002 Help! stevenzdrenka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-19-2010 01:47 AM
Flashing Scribble Strips Digi 002 Help! stevenzdrenka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-18-2010 11:25 AM
002 control surface blank scribble strips Ryan Butler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-15-2008 11:34 AM
Dim scribble strips pigpen ICON & C|24 1 05-03-2006 08:35 AM
DIGI HELP!!! Scribble strips dim and flicker. McMasters ICON & C|24 15 11-01-2005 12:14 PM
