Re: how to monitor and mix the low end
Great advice that helps thanks
Probably best to frequently compare your work to good reference material at the same RMS level while mixing.
Yeah true
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
#16
#17
Your best asset right now will and forever be your ears. Analyzers of that nature are great for momentary glances into your work, but your ears must be the final determining factor. Cross-referencing your mixes with your favorite recordings helps too. Regardless as to how your room is set up, when you listen to your mixes in that environment and up against your favorite recordings, it gives you a general idea of your progress. Also keep in mind that listening in multiple environments and on many mediums helps as well.
Work with what you have, adapt and improve. I wish you the best of luck! |
#18
I have a pair of Yamaha HS80s. I replaced my old HR824s with them after using them on site at a post house I do jobs for. Good stereo image. The room controls helped a great deal in my home space but were still a little on the big side, but translated way better than the 824s. I have since replaced them with JBL LSR305s after doing AB tests with MANY different monitors including Focal (several models), Neumann, ATC, Genelec, et al. For the price they were pretty close sonically to Focal CMS 65, which I really like a lot.
When I was working at LucasArts I used Meyer HD1s in my office and they are without question my favorites to mix on, but they are way too much, both physically and pricewise for my home space. I've also used Genelec 1031s which I also like and got used to. Don't like their die cast lines at all. I had 8040s and 8030 systems and never got a good translation with them. I am getting excellent translation with the 305s but I intend to invest in the SE Electronic Munro Eggs ultimately. Guys I respect really like them and claim they are fairly room proof. Agreed about using a reference mix for low end. |
#19
#20
Using your ears though means "try everything for 10 years and have confidence about the results after you have done the practice"
Dual monitor vs single monitor setup | Whasssaaahhh | Pro Tools 9 | 23 | 03-17-2014 01:24 PM |
Can Studio Monitor Express & Transport act as digital monitor controller? | briancares | Artist Series | 1 | 02-04-2014 05:23 AM |
MBox 2 Pro Monitor knob has stopped changing monitor levels | Rumandolin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-21-2013 09:13 AM |
Pro Tools 10 / CPU Monitor low -> System Monitor high | mpeg5 | Pro Tools 10 | 0 | 12-09-2011 08:45 AM |
Dual Monitor / hardware playback with NTSC monitor | TheBriceShow | Post - Surround - Video | 2 | 02-21-2005 05:58 PM |
