How hot i7 960 ?
I'm a complete computer noob when it comes to things like this. How hot should my processors cores be when in heavy use. What is a typical temp that they shouldn't get to. I'm just investigating do that I can see of my PC is overheating :)
Cheers
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: How hot i7 960 ?
my i7 6core when overclocked usually runs 45 degrees...... F
It's been awhile since i have looked but I used to have software that would measure that..... Standard air cooler.....not water cooled..... Passive CPU cooling.
Wow mine is running at 67 degrees is this bad its not over clocked its the one which has 4 cores but shows 8 if that makes any sense lol
Raoul Crane
http://www.tomshardware.com/forum/280887-28-temps-okay
check that fans / blowing correctly / how how is your room / paste on the cpu b/t the cooler and the cpu?
I have IIRC 2 fans in the case, thermo paste on the i7 some fan that sits on the i7 aswell my room can get quite hot. As you can see I'm not that computer illiterate at these kind of things
Raoul Crane
40-50C is normal. Most PC's are set to shutdown if temps hit over 70C
So mines too hot then??? How do I set it to shut down if it gets to hot?? Is that in the bios ??
Raoul Crane
yeah but not all BIOS's are created the same so you will just have to have a look.
A good case cleaning might help your temps....."the ever falling dust" Also you might want to invest in a better cooler......at least pull the old one off and take a look-see. I have a cooler master V8......(big honker for sure)
Spoke to the guy who built my PC and I asked if there was a way to make it cooler maybe add another fan etc. His reply was to buy another motherboard and processor ????
Is this the only way, I hope not ???
Raoul Crane
