Roger Nichols Analyzer
Since Roger Nichols is no more (RIP) I can't update my Inspector XL anymore ((..Looking for a similar 1/3 octave 31 band spectral analyzer (plug-in RTAS, VST, AAX)
What this spectral analysis should display is: 1. On the X plane (Hz), 20-20,000 Hz. 2. On the Y plane (dB), -36, -24, -12 dB, 0db. (-90dB to 0dB, will do). I used Spectra Foo before, as well as waves and need something that will show band division in blocks!! Here is an example http://www.hitsquad.com/smm/programs...reenshot.shtml Thanks in advance
Audio Mastering Engineering & Production |
Re: Roger Nichols Analyzer
You can't beat spectra foo! but for free try this one... http://www.bluecataudio.com/Products...t_FreqAnalyst/ Chris
Here is what Blue cat people said: "Thank you for your interest in our plug-ins. Our spectrum analyzers do not offer 1/3 Octave display. They show a continuous display with a maximum resolution of a couple of hertz." Spectra Foo is stand alone, can I use it with Pro Tools?
This should give you what you want, and a whole lot more...
iZotope Insight
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
Thank you anyways.
Not sure if this is the plug in that you are referring to.. posted on the Air-Users-Blog/Pro Tools Expert.. recently...
http://www.pro-tools-expert.com/home...-ins-list.html Using RND Inspector w/ Pro Tools 10.3.2 on a 2008 Mac Pro running Lion 10.7.5 (no PowerPC; no Rosetta) and it works. The inspector.dpm file is a Universal Binary so it does run on Intel processors....However? |
The .dpm installer may actually work. I just never used it.
The installer is the problem.. some permissions thingy.
Anyhow i did same thing on Mac, right click, show contents and navigate to the .dpm .vst .component Drag out along with the PDF etc and place in your plug in folder. This plug in should be the first into the Plug in Hall of Fame for its survival rate |
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
RIP Roger Nichols | jmitchell1532 | General Discussion | 2 | 04-22-2011 01:41 AM |
Roger Nichols R.I.P. | woodsdenis | Pro Tools TDM Systems (Mac) | 13 | 04-13-2011 01:39 AM |
Roger Nichols needs our help | fsilano | General Discussion | 1 | 01-27-2011 01:57 PM |
vs Roger Nichols | ByPass | Pro Tools TDM Systems (Mac) | 9 | 02-22-2010 11:34 AM |
Help on a free Roger Nichols spectrum analyzer | oulablank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-16-2008 11:18 AM |
