Old 12-10-2018, 08:04 AM
Cochio's Avatar
Cochio Cochio is offline
Default Artist Mix meters don't work (PT LE 10.2.0)
Hi everyone,
as said in the title, meters don't appear very well. I mean I only saw meters on track 1 work. But just one time. It disappeared since.
EuControl is 3.7.0
Should I try older EuControl versions ? Do I have to uninstall it before ? How to do so please ?
iMac 27 Intel Core i5 3.1 GHz
OS X 10.7.5
Pro Tools 10.2.0
12 Go 1333 MHz DDR3
Digi 002R via FireWire 2m 400Mb/s
Artist Mix (v2) via 1m Ethernet
EuControl 3.7.0
10,1'' HDR IPS UPERFECT monitor via 3m Thunderbolt + DVI + mini HDMI adapter
Old 12-12-2018, 09:31 AM
Default Re: Artist Mix meters don't work (PT LE 10.2.0)
I am a bit confused. If you are using Pro Tools 10.x(there is no "LE" anymore) then its possible you may need an older version of EUCON. I am running the current(18.3?) version with PT 2018.10 and the meters all work here. Having said that, with meters showing much clearer on screen, I rarely even notice them on the Artist Mix
artist mix + digital performer = meters problem zejuju Artist Series 31 06-07-2017 02:15 AM
Meters for the Artist series ? Gemylon Artist Series 9 05-08-2017 01:25 PM
Artist Mix has lost the meters with Eucon 3.3 maaaquemeseyo Artist Series 3 08-08-2015 07:01 AM
Next Victim - Artist surfaces do not work with PT11 but work fine with PT10 jimmyjayp Artist Series 10 12-29-2014 03:38 PM
peak meters on rec track dont work during playback AfricanCaneKing 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-28-2004 04:57 PM
