Old 04-17-2008, 09:06 PM
Braveheart Braveheart is offline
Default Newbie: Get no signal from M-Audio Octane via ADAT
Near final confguration of new system. 003 rack, XP, Glyph 250. Worked out all the OS kinks by dropping Vista, going to XP and setting up a hardware profile with all the ethernet, ect disabled. Get good signal from sm57 via rack's pre's 1-4.
Added an M-Audio Octane 8 channel pre. Light pipe line in place. Setup=>Hardware to get clock from ADAT at 48k. Get steady synch light showing ADAT clocking.
Get no signal from SM57 via any of 1-8 pre's at full gain?
I Setup=>I/O to Default so I can see all 8 rack analogs and 8 ADAT ins and when I add Adat 1 for instance as the input, I got nada.
I can't see where I am supposed to set the bit width and maybe I need to do some other setting to make the rack aware of the Octane? Total newbie, lots of reading and practice with mixing but not yet up to speed on getting wired right.
M-Audio Octane to add on to PJM I/O carterobrien Pro Tools TDM Systems (Mac) 0 11-10-2009 01:09 PM
Digi 002 M-Audio Octane ADAT clock problem! the 5cientist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-31-2009 08:32 PM
M-audio Octane, and ADAT (toslink?) w/CoreAudio KamaSutra77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-22-2005 10:59 AM
002r ADAT out to monitor with octane HELP!!!! AM STUDIOS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-17-2005 07:42 PM
002r ADAT out to monitor with octane HELP!!!! AM STUDIOS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-16-2005 10:24 AM
