Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 10-17-2015, 07:58 AM
tangoportland tangoportland is offline
Default Thunderbolt 3
Hello DUC, I am looking at the Focusrite Scarlett 18i20 , for a PC. Or an interface for around $500.
I have just read a little about Thunderbolt 3.
Hoping to find a set up that will be compatible & up to date for at least 18 months....
https://en.wikipedia.org/wiki/Thunde...#Thunderbolt_3
1. Does anybody have knowledge about an interface using Thunderbolt 3 and which interfaces would be compatible?
2. Installing a card into the PC that will do Thunderbolt 3 for an interface?
-----------------------------------------------------------------------------PRO TOOLS 11.3 MBOX 3
Windows 7 Intel vPro : 8.00.10.1464
Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Memory Controller : MSI Core (Sandy Bridge) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.33GHz 128-bit, Integrated Graphics
Memory Module : 2 Super Talent SUPERTALENT02 8GB DIMM DDR3 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6)
Video Adapter : Intel(R) HD Graphics 3000 (12CU 60SP SM4.1 850MHz/1.1GHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics)
Compute Shader Processor : Intel(R) HD Graphics 3000 (60SP 12C 850MHz/1.1GHz, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics)
WDC WD5002AALX-00J37A0 (500.1GB, SATA300/600, 3.5", 7200rpm, 32MB Cache) : 466GB (C:)
LaCie Rugged USB3-FW (500.1GB, USB3/SATA300, 15MB Cache) : 466GB (E:)
System Reserved : 100MB (NTFS)
Hard Disk (E:) : 466GB (NTFS) @ LaCie Rugged USB3-FW (500.1GB, USB3/SATA300, 15MB Cache)Hard Disk (C:) : 466GB (NTFS) @ WDC WD5002AALX-00J37A0
Old 10-17-2015, 08:48 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Thunderbolt 3
Is there even an interface that uses TB2? I mean, for audio interface TB1 is more than fast enough.
Janne
Old 10-17-2015, 08:53 AM
Southsidemusic's Avatar
Apollo uses TB/2 but not seen any TB/3 interfaces yet
Best Regards
Christopher
South Side Music Group
WEBHOME
”Pro Tools always wants to close and relaunch though, which is pretty annoying... especially when it never seems to manage the 'relaunch' bit. I'm sure it used to do it” - Quote LDS 2019
Old 10-17-2015, 09:12 AM
JFreak's Avatar
Okay :)
Janne
Old 10-17-2015, 11:05 AM
Wall2Wall Wall2Wall is offline
I don't believe there has been an officially supported Windows/PC thunderbolt unit as of yet. Windows has yet to work out their security and other issues with thunderbolt. But online, some guys have gotten windows/TB set ups to work. Both UA Apollo TB and HD Native TB.
Old 10-17-2015, 01:08 PM
Craig F Craig F is offline
a) There is nothing TB3 shipping that I know of
b) No, you can not just as a card to any computer to get TB. You have to have a motherboard that supports TB ether directly on the motherboard or via a special TB card but you can not just stick one of the TB cards into any motherboard
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 10-17-2015, 01:26 PM
It looks like options are in the making: There must be something brewing, but it is probably above my pay grade! I know as soon as I up grade then the manufactures will.
Gigabyte Technology has revealed its new Z170X-UD5 TH motherboard. This Skylake processor supporting (LGA1151) motherboard is claimed to be the world's first to be the Intel Thunderbolt 3 certified. Thunderbolt 3 connectivity is available over either of the two reversible USB Type-C connectors on the rear I/O panel.
http://www.gigabyte.com/products/pro...px?pid=5479#ov
Old 10-17-2015, 03:08 PM
VRW VRW is offline
Focusrite announced Windows support coming for their new Thunderbolt interfaces, the Clarett series.
Those seem to be pretty cool stuff particularly for this price range and there will be units available with
2 micpres (for around $500.-), 4 micpres (for around $700.-) and two 8 micpre units. Check it out there.
http://global.focusrite.com/thunderb...s/clarett-8pre
http://global.focusrite.com/clarett-range
http://www.sweetwater.com/store/sear...usrite+clarett
If you can afford more the UAD Apollos are always a good idea .
HD native thunderbolt through Echo Express SE Thunderbolt Chassis hkj1 Pro Tools HDX & HD Native Systems (Mac) 1 11-06-2013 06:49 PM
thunderbolt HDs frcjt Pro Tools Software (Mac) 1 01-23-2013 12:07 PM
Until Someone Makes a Thunderbolt Hub, Thunderbolt is a (1/2 Useless) Dead End Street relaxo Pro Tools 10 7 11-12-2012 12:43 PM
Hdx thunderbolt ilulilu888 Pro Tools HDX & HD Native Systems (Mac) 9 09-17-2012 12:26 PM
Thunderbolt-Sonnet’s Echo™ Express PCIe 2.0 Expansion Chassis with Thunderbolt™ Ports Barry Johns Pro Tools TDM Systems (Mac) 29 08-11-2012 08:01 AM
