Old 03-31-2016, 03:04 PM
john1192 john1192 is offline
Default Re: Command 8 - Compatible
thx for the update .. hope you can get it repaired ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 07-01-2019, 04:17 AM
hornedrum hornedrum is offline
How did you all get Command 8 working?
I just upgraded from PT 10 to 12.5.2, on Sierra OS and can't get the Command8 to be seen at all.
Do I need EUcontrol software installed, and if so, should that be an earlier version like 3.7 which worked on Mavericks, or there latest version on the AVID site?
Thanks
Old 07-01-2019, 05:30 PM
Top Jimmy's Avatar
Default Command 8 - Compatible
Thanks
No on the Eucontrol.
You need to set up the Command8.
Setup menu > Peripherals > MIDI controllers.
James Cadwallader
D-Command Firmware update backwards compatible? inky macOS 4 09-18-2014 01:48 PM
Command Keyboard Focus mode ' E ' command bug ? vudoo Pro Tools TDM Systems (Win) 2 09-10-2009 05:49 AM
Leopard / PT 7.4-PR / Command|8 not compatible? eric22rr ProControl, Control|24, Command|8 2 06-10-2008 11:38 AM
Total Loss of Command 8 Command/Modifiers John Pisciotta ProControl, Control|24, Command|8 1 05-13-2005 10:30 AM
Command 8 ANd 001 compatible? eddierojas ICON & C|24 0 04-05-2004 07:47 PM
