Amplitube engine will not load
I have recently reformatted my system and reinstalled Pro Tools and all of my plugins with no problems except for Amplitube. This is version 2.0 which is the mono to stereo plug.
I am working on a session that had an instance of amplitube. It will not load. I get 2 messages. 1) "AT Engine could not be loaded" then: 2( "The Plug IN could not be made active because a DAE error was encountered. (error #-7401)" Has anyone encountered this before and how did you fix it? I searched the answer base and this forum and found nothing there. Please help, Bassist
Critics wouldn't know music if it bit them on the ass... -Frank Zappa |
Re: Amplitube engine will not load
sorry... my version is 1.2
I type too quickly. Thanks... B-
bumpity bump bump bump...
C'mon...surely I am not to only one to have ths problem.
Have you reinstalled Amplitube? It sounds like a copy protection issue.
You should be able to import the session to a new one without importing the track with Amplitube... or remove Amplitube from the DAE Plug-ins folder. Rail
thanks Rail Jon...
I can always count on you. I got it worked out, thanks...
amplitube: how to load saved settings | pre911mindset | Virtual Instruments | 0 | 12-31-2008 06:40 PM |
Amplitube won't load: error 7400 | Brain Juice | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-08-2005 11:34 PM |
Amplitube Upgrade WILL NOT LOAD CORRECTLY!#$*#($)# | gbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-01-2003 10:46 PM |
Couldn't Load Video Engine (?) | mmyers | Pro Tools TDM Systems (Mac) | 2 | 04-30-2002 07:13 PM |
Video Engine doesn't load sometimes | soundasylum | Post - Surround - Video | 0 | 08-30-2001 05:58 AM |
