protools 7-band EQ problem (rewrite parameter on clips that are not selected)
Hi there,
I've met a problem of the 7-band EQ, hope someone can help me out. For example, If I insert a native EQ on a track. Within a track I have two clips which I plan to write different EQ parameter on them. Normally I would bypass the whole track and de-bypass only the clip I want to write automation on. What happened was, when I finished writing the EQ on the first clip, I wrote a different EQ on the second clip, the EQ parameter on the second clip shows on the first clip when I check after I wrote the second clip, means that now my second EQ parameters shows on both clips. It seems like my second clip's EQ parameter rewrite the first clip, which is weird. I only highlight the clip I am about to write, which shouldn't change the parameter on other clips. This problem doesn't happen every time. Is there anybody knows why? Thank you very much! |
Re: protools 7-band EQ problem (rewrite parameter on clips that are not selected)
Not sure, but your method seems convoluted to me. If I need different EQ at points on the same track, I would usually insert 2 EQ III plugins and automate the BYPASS button so each EQ plugin is only on when needed. Alternately, I might choose to treat each clip with the Audiosuite version of the EQ
making playlists for selected clips?? | Felix | macOS | 2 | 07-27-2017 08:36 AM |
Change Track View "vol" or Pan parameter only on selected Tracks | joachim | Tips & Tricks | 0 | 12-03-2015 07:05 AM |
Clear selected clips shortcut not working hd 10.3.2 | dgoodi22 | macOS | 7 | 02-08-2013 04:49 PM |
Protools 7... Code rewrite!! | de_mix | Pro Tools TDM Systems (Mac) | 18 | 10-31-2005 08:56 AM |
Need help bouncing only selected clips | Simpson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-22-2005 01:40 PM |
