Massive Static/Fuzz on Playback/Record
I'm getting a massive amount of digital static/fuzz through Pro Tools. I only hear it when there is any output, so I know it must be coming from Pro Tools itself.
I spent a few hours on the tech support line, and the problem disappeared after the operator turned off Microsoft Defender. However, the problem returned the next day, and remains even when I disable Defender. Every 3rd or 4th time I open Pro Tools the static will disappear, but there is no real rhyme or reason to why it changes. Does anyone have any idea what might be causing this? It's impossible to use Pro Tools with this going and this Mbox/software is brand new. Worked fine for 1 day then this started happening, and it's driving me crazy! |
Re: Massive Static/Fuzz on Playback/Record
Help us Help You - READ THIS Before Posting!
Hi, you need to go through everything in the link, including the Windows 7 Optimizations, and post a SANDRA report.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I haven't had any luck with searching the forums yet, but I'll keep trying. In the meantime here is the SANDRA (this is a computer I built): SiSoftware Sandra ID Host Name : Blue Workgroup : WORKGROUP Computer Model : OEM Serial Number : To Be Fille*********** Chassis : Desktop Mainboard : ASRock H61M-VS BIOS : AMI (OEM) P1.10 03/03/2011 Intel vPro : 7.00.04.1197 Total Memory : 8GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (4C 3.49GHz/3.7GHz, 3.5GHz IMC, 2x 256kB L2, 6MB L3) Socket/Slot : FC LGA1155 Chipset Memory Controller : ASRock Core (Sandy Bridge) DRAM Controller 100MHz, 2x 4GB DIMM DDR3 1GHz 128-bit Memory Module(s) Memory Module : G.Skill F3-10666CL9-4GBRL 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : G.Skill F3-10666CL9-4GBRL 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : ACI ASUS VH242H (1920x1080, 23.4") Video Adapter : NVIDIA GeForce GTX 550 Ti (4CU 192SP SM5.0 1.9GHz, 1GB 4.36GHz 192-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce GTX 550 Ti (192SP 4C 1.9GHz, 1GB 4.36GHz 192-bit) Compute Shader Processor : NVIDIA GeForce GTX 550 Ti (192SP 1.9GHz, 1GB 4.36GHz 192-bit) CUDA GP Processor : NVIDIA GeForce GTX 550 Ti (192SP 4C 1.9GHz, 384kB L2, 1GB 4.36GHz 192-bit) Storage Devices WDC WD5002AALX-00J37A0 (500.1GB, SATA600, 3.5", 7200rpm, 32MB Cache) : 466GB (C:) Logical Storage Devices System Reserved : 100MB (NTFS) Hard Disk (C:) : 466GB (NTFS) @ WDC WD5002AALX-00J37A0 (500.1GB, SATA600, 3.5", 7200rpm, 32MB Cache) Peripherals LPC Hub Controller 1 : ASRock H61 LPC Controller LPC Legacy Controller 1 : T0 B0-73 Audio Device : ASRock Cougar Point High Definition Audio Controller Audio Codec : VIA VT1708B/1702S/1708S HD audio codec Audio Device : EVGA GF116 High Definition Audio Controller Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : ASRock Cougar Point 4 port SATA IDE Controller Disk Controller : ASRock Cougar Point 2 port SATA IDE Controller USB Controller 1 : ASRock Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : ASRock Cougar Point USB Enhanced Host Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Wireless Adapter : TP-LINK 150Mbps Wireless Lite N Adapter (802.11n (HT), AES-CCMP, 150Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
Hi, first time poster here, sounds like exactly the problem I'm having. The playback quality is fine for a while, then for no apparent reason it sounds awful... fuzz and static is a good way to describe it.
I've been trying to work out what triggers this, and so far I can't find any pattern - it will work fine for a few minutes but then it happens again. Sometimes restarting Pro Tools fixes it, but sometimes it doesn't. Then I will re-open some time later, and the sound is fine again - very frustrating. I have reinstalled Pro Tools 10, and updated to the latest Mbox Mini drivers. Sandra report: SiSoftware Sandra Computer Model : Samsung 700G7A Processor Model : Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz Speed : 3GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Samsung 700G7A BIOS : AMI 01FF.M002.20110818.SCY 08/18/2011 Bus(es) : PCI PCIe USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : No Total Memory : 8GB DDR3 SO-DIMM Chipset Model : Samsung Sandy Bridge DRAM Controller Front Side Bus Speed : 1x 100MHz (100MHz) Total Memory : 8GB DDR3 SO-DIMM Channels : 2 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : Samsung M471B5273DH0-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Samsung M471B5273DH0-CH9 4GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : AMD Radeon HD 6970M (SM5.0 680MHz, 2GB 900MHz, PCIe 2.00 x16) Graphics Processor OpenCL Processor : Barts (960SP 12C 680MHz, 800MB) Compute Shader Processor : AMD Radeon HD 6970M (2GB 900MHz) Storage Devices SAMSUNG HN-M101MBB 1TB (SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 932GB (C:) (D:) SanDisk iSSD P4 8GB 8GB (SATA300, 1.8", SSD) : 7GB SAMSUNG HN-M101MBB 1TB (SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 932GB (E:) TSSTcorp DVDWBD TS-LB23D (SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) DTSOFT BDROM () : N/A (G:) Logical Storage Devices SYSTEM : 100MB (NTFS) 2ndHDD (E:) : 932GB (NTFS) @ SAMSUNG HN-M101MBB 1TB (SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) Hard Disk (D:) : 545GB (NTFS) @ SAMSUNG HN-M101MBB 1TB (SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) Hard Disk (C:) : 362GB (NTFS) @ SAMSUNG HN-M101MBB 1TB (SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) SAMSUNG_REC : 24GB (NTFS) Optical Drive (F:) : N/A @ TSSTcorp DVDWBD TS-LB23D (SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (G:) : N/A @ DTSOFT BDROM () Peripherals LPC Hub Controller 1 : Samsung Cougar Point LPC Controller Audio Device : Samsung Cougar Point High Definition Audio Controller Audio Codec : Realtek Semiconductor High Definition Audio Audio Device : Samsung AA88h Audio Codec : ATI (AMD) HDMI Audio Disk Controller : Samsung Cougar Point 6 port SATA AHCI Controller Disk Controller : Samsung 5209h USB Controller 1 : Samsung Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Samsung Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : Samsung 1042h SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller Network Adapter : Bluetooth Device (Personal Area Network) Wireless Adapter 1 : Intel(R) Centrino(R) Advanced-N 6230 (802.11g (ERP), TKIP, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.9 Anyone have any ideas? Many thanks in advance. |
What kind of Mbox is it? USB/Firewire? If it's Firewire, you could try the other drivers like legacy and see if that works better.
Did you do all the Windows 7 Optimizations? Are you recording to a second hard drive at least 7200 rpm? CattleRoyale - all three of your hard drives listed are 5400 rpm. Avid requires at least 7200 rpm hard drives. Doesn't mean it won't still work, but it won't be optimal. It may be the source of your problem too, depending on the size of your sessions.
Hi cwsand, many thanks for the response. I will try with a faster drive.
Thanks for the reply.
What confuses me about this issue is that it sporadically works, then will not work, then works again without any change to my system, interface, programs running, etc. It worked fine all of last Friday but I came home tonight to edit some work and I hear fuzz with some music barely audible underneath. I really want this program to work consistently so I'll pay for a new hard drive if absolutely necessary, but I would hate to spend that money and have Pro Tools still output static. |
For anyone else who may have this issue, temporary but not permanent fixes have included:
- Disabling all network adapters - Disabling all sound cards (mine is integrated into the mobo) - Running windows for optimal performance (makes your system look like Windows 98) - Disabling Turbo Boost in the BIOS - this made it work for about 2 days straight, but I'm getting fuzz again today - Disabling Microsoft Defender - Disabling Windows' ability to throttle power of usb devices I'm on hold for technical support now, will update with any other fixes. Last edited by djl62490; 01-09-2013 at 03:57 PM. Reason: Forgot something |
I'll be picking up an external hard drive this weekend, will update with progress.
I installed a WD Caviar Blue 1 TB internal hard drive for Pro Tools use only yesterday, unfortunately the problem persisted.
I was also told by tech support that they don't know what else to do on the computer end, his only suggestion was buy a new usb cable and if that doesn't work, install it on a new system to see if the computer hardware is the issue. I'm really !@#$%ing bummed about this. I saved up for a while to buy this program and it's essentially unusable on a computer that in every way should be compatible. I'm not even sure if they'll let me refund for my money. Best of luck CattleRoyale, I hope you have more success than I did. |
Mbox Mini static/crackling/fuzz from computer output | djl62490 | FireWire & USB Audio Interfaces (Win) | 1 | 01-20-2014 09:52 AM |
Digital Static / Fuzz / Noise with 8.0.4 | Chase743 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-24-2010 06:28 AM |
Fuzz/ hiss on Playback/Record | JGIARRA | General Discussion | 4 | 01-12-2009 10:54 AM |
I get fuzz/static on the external pre-amp (003 Rack) | mattvivsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-08-2008 03:06 PM |
low output noise & crackling fuzz static on outputs after years of no problems | M-Link | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-14-2003 12:38 AM |
