Memory Markers and tempo events won\'t move when I shift audio and MIDI tracks
I spent a lot of time programming MIDI drums on a song yesterday. I have about 12 memory markers, and just as many tempo events, placed exactly at the right bar counts. I then needed to shift the whole song by 8 bars in order to give a little room from when I play start/rec to when I have to start playing the instruments. So I used the shift command to push back all audio and MIDI tracks by 8 measures. This worked fine, except that it didn't shift the memory markers and the tempo events. I had to shift all of those by hand, which is a royal pain.
Is there a way to shift those as part of the track shift, or is there at least a way to shift multiple memory locations and/or MIDI tempo events in one command? Help appreciated.
Digi002 Rack Mac Pro 8-core 3Ghz 8gb RAM 3X 500GB 7,200 SATA DRIVES OSX 10.5.7 PTLE 8.0cs3 |
Re: Memory Markers and tempo events won\'t move when I shift audio and MIDI tracks
how exactly do you mean 'shift' command?
if you select a region and want to move the markers/tempo/whatever with it, do the following:
I selected all the tracks, then in the Edit menu, I chose a command to shift the tracks. I was asked if I want to shift them "earlier" or "later". I picked "later", and entered an 8 bar shift.
How do I change the tempo and not have it move markers? | aasteveo | Tips & Tricks | 4 | 10-16-2019 01:20 PM |
Aligning Midi to Tempo Map with Beat Detective-Can't move analysis markers. | Dizzi45Z | Tips & Tricks | 7 | 08-25-2015 02:35 PM |
Move the red diamond in the tempo bar in the edit window, only some tracks move | kingheartless | macOS | 2 | 02-21-2013 03:20 PM |
Can memory location markers move with midi edits? | Jepse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-27-2005 11:51 AM |
how do i move all tracks WITH MARKERS ??? | Kenny Gioia | Tips & Tricks | 5 | 04-10-2001 10:21 PM |
