MBox Hardware Problem???
Hello,
I'm new to Mac ( Imac Intel, Snow Leopard 3.06 Ghz) and I've just now gotten all my apps installed. I've opened my PT LE 8.0.3 and all seems to be in order although I still have to transfer my old session files over to the mac. I have been fooling around with GarageBand (I know this is not a GB forum) and been experiencing some problems that seem to be hardware related i.e. intermitent recording input signal, high pitched tone whenever audio programs using the Mbox are opened and last night I switched off the monitor amp to use headphones and the left side of output went away. Rebooting seems to help, like right now I booted and all is well in my headphones but I haven't switched on the monitors yet. I have other USB devices plugged in but not on. I've read over this... http://duc.digidesign.com/showthread.php?t=54888 ...and I'll endeavor to follow many of these guidelines but could this problem be something as simple as a bad USB cable? If that's possible would any USB cable with appropriate jacks work with the Mbox? Thanks... |
Re: MBox Hardware Problem???
What a way to spend New Years Eve! At least I have a bottle of Veuve Clicquot Ponsardin.
The latest... I've pretty much pinpointed the source of the problem although I'm still not sure what is to be done about it. I now believe that the my monitor amp has something to do with the problem. When I use the headphones only I get no high freq pitch. When I turn the monitors on the pitch is there and the input level meter shows a constant level ...at about 0db but no input signal is possible when the meter locks up this way. It is intermittent so it works some of the time but I believe that whatever is causing this tone/pitch is the cause of the cutout. I may need to take the amp in to have it looked at but I'd still like to know how this is causing the Mbox record input to screw up. |
Hmmmm...... Maybe because the MBox is not supported with 8.0.3???
Only MBox 2 /Pro/Mini/Micro |
Sorry should have been more specific...I have an Mbox 2 mini.
Problem Mbox Pro 3rd Generation - HARDWARE NOT CONNECTED | Zangra | FireWire & USB Audio Interfaces (Mac) | 0 | 08-21-2013 04:42 AM |
Can't Find Hardware Problem - I don't use hardware! | sevenk | Pro Tools 10 | 3 | 10-29-2012 09:55 AM |
Mbox mini installation problem - "Hardware Not Found" | tinsoldierman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-18-2010 03:06 AM |
Mbox 2 Inaudible -10dB "noise" on one channel - hardware problem? | andreuso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-19-2009 10:00 AM |
Unable to locate hardware - OS problem or hardware problem? | Petie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-16-2007 05:07 PM |
