Old 01-13-2014, 02:01 PM
danjfoley danjfoley is offline
Default MIDI Input from keyboard, lag before hearing sound
I have protools 8 LE, an BOX 1, and a MIDI Sport 4x4.
Everything was working perfectly last week. (i might just have to restore my computer.. but some software I install.. a new version of quicken, needs to stay so i hope it didn't cause the problem).
Here's what happens now:
Instrument track, with my controller set to input. I press a key on the controller, 1/2 a second later i hear it.
MIDI track - input set to my controller, output set to a real protues sound module. 1/2 second delay. You can actually watch it on the MIDI sports lights. when i press a key on the controll, the input lights up in real time. 1/2 a second later the output lights up.
This suggests the delay is software. Protools is either hearing the input, and waiting a 1/2 to output it, or it is having a 1/2 delay hearing the input.
Please help. This was never an issue before. It was all nice and real time.
Old 01-13-2014, 02:25 PM
Southsidemusic's Avatar
Default Re: MIDI Input from keyboard, lag before hearing sound
Hi and Welcome to The Forum
Whats your buffer size set to? Also the issue you describe points (IMHO) to hardware issues with the Midi Sport. When we have had similar latency our 8X8 midiman Midi sport midi interface never lagged in the in and out lights. Only heard latency in pro tools. I may be wrong but to me this sounds like an issue with outboard gear like your synths and midi setup. Cables, connections etc.
Set the buffer to 64 and see if the lag persists,
Christopher
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 01-13-2014, 02:50 PM
Everything was fine last week, and i didn't change a thing. Other then installing some software. Notable Quicken 2014.
I tried adjusting buffer size and it has no effect.
Old 01-13-2014, 02:55 PM
Well if that is the ONLY changes you made and no other updates from any other program or plugins, delete it and see if it works, then you know if this is due to Notable Quick or something else. We can speculate to no end and if this is the issue why not try that first,
Chris
Best Regards
Christopher
WEBHOME
MIDI input via computer keyboard. vinylrider macOS 1 05-31-2013 08:27 AM
MIDI input via computer keyboard. vinylrider macOS 0 05-31-2013 08:15 AM
Keyboard midi input not recognized rthomas73 MIDI 2 03-31-2011 04:27 PM
Manual MIDI vs Keyboard Input AirborneFO MIDI 3 05-19-2009 12:12 PM
Using your computer keyboard as input for MIDI PaulG1522 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-03-2007 03:09 PM
