#101
Re: Best foot controller for use with Eleven Rack?
I really liked the LF jr. but found it had just a few too few buttons for me. Steve |
#102
you sold your Ultra.... ok.
I liked the size of the JR and its price, the GCP is as much as the 11R here..reckon id have a hard time trying to justify that to the mrs! |
#103
Yeah I liked the Ultra as a tweaking machine and it really does sound great, but I personally did not love it for live use. I know a lot of great players do but for me I really want some live knobs on the front.
I actually sold it 2 weeks before the 11r came out. I had no idea that Digi was coming out with the 11r. I was going back to my old modeling rig with a tecj 21 liverpool and an m13. The 11r sounds really great to me as did the Axe FX but the live knobs are what sold me on the 11r. Steve |
#104
Ground Control Pro update:
I finally got around to setting up my GCP with the 11R. After struggling for a few moments to re-understand the lingo of the pedal, it was pretty smooth from there. I have had the pedal for 4+ years but it's been about that long since I edited anything in it. The pedal is set up as follows: -Big numbered buttons 1-4 on the GCP are for my patch changes (YES you can be in bank 2, 3, 4, etc and still program any of the buttons 1-4 to point to any patch within 11R). For instance, I have my main distortion in the 11R at A1. In banks 1 and 2 so far, button number 1 points to that same A1 rig. I know some guys are having issues having to save a rig in multiple spots which causes issues if you make an edit...you have to edit all of the copies. I guess it depends on your pedals capabilities??? -Small numbered buttons 1-7 are for my CC's to turn the stomp box effects on and off. If I remember correctly, the GCP can be set up to have the lights on the pedal already lit on patch changes to match what effects are already on for the respective rig. My manual doesn't seem to talk about this and I can't remember how I did it back in the day. If anyone knows how to do this please do tell! -Small numbered button 8 is to turn my Wah on and off. Then I can slide my foot right over to my expression pedal to control the Wah. I have a second expression pedal that will most likely control volume on all of my presets. So is the GCP the "best" foot controller for the 11R, not sure, but it's a damn good option for the price. If anyone has questions feel free to PM or post here! ~jerry
PRS CE22, Parker Dragonfly - Dutkiewicz, Martin 000CXE Eleven Rack, Axiom 61, Ground Control Pro |
#105
for the price, isnt is expensive?
#106
it is $400 new, $250-300 used. For what it allows you to do and the control you get, I don't feel it's expensive but that is just my opinion.
#107
#108
I have re-discovered how to set this up. You have to have the GCX 1 expander turned on in setup mode. Exit and save. Then using the pedal, select the patch you want to match. Initiate the buttons to match the effects currently turned on, on the 11R and enter EDIT mode. Scroll through until your screen reads "GCX" and again initiate the effcts to match. Exit and save. This should allow you to make patch changes and have the GCP follow along to match your rigs and what effects are on/off. Note: I own a GCX and use it to power my GCP so I cannot test to see if these instructions work without actually having a GCX. My thought is that it would work but if anyone can confirm that would be great. Good luck!
#109
Jerry - thanks for putting this info together. You are the go-to-guy for GCP/11R.
#110
Tnhanks Jerry, for sharing your info....I'm broke so I haven't purchased the VLGC Footpedal yet. Maybe that's a good thing...lol...I was hoping by the time I have the coin, it will be a fairly easy transition to program..
[SOLVED] FCB1010 Foot Controller (stock PROM) with Eleven Rack | The Sentinel | Eleven Rack | 12 | 10-10-2018 12:18 PM |
FS: Eleven Rack with FCB1010 Foot Controller | J-mo | Buy & Sell | 0 | 07-08-2012 11:27 AM |
Advice for Foot Controller and Rack/Case for Eleven Rack? | udamann88 | Eleven Rack | 19 | 03-08-2011 06:24 PM |
tonelab LE as foot controller for eleven rack? | remis | Eleven Rack | 2 | 01-20-2011 02:03 PM |
THE FOOT CONTROLLER for the Eleven Rack and any other rack modeler for that matter.. | vkaxeman | Eleven Rack | 3 | 01-19-2011 04:13 AM |
