Is There A Better Way TO Export Audio/Bounce Audio
Is There A more efficient Way TO Export Audio/Bounce Audio? I dislike the way protools bounces audio, it plays back the whole song. While this is fine if i am bouncing a whole mixed down track, This can be VERY monotonous and time consuming if I need to export each individual channel (which I usually do in my line of work). Is there a quicker way to export audio (the way Reason, Acid, Cubase etc. do it) or even better...is there a way to bounce each channel individually with one command?
Re: Is There A Better Way TO Export Audio/Bounce A
Re: Is There A Better Way TO Export Audio/Bounce Audio
Auditory,
Welcome to the board.. Yes, there is a quicker way. Highlight the track/s in question on the "region list" plane (right side of the edit window), once they're selected you can "export selected as.." from the title bar. You'll be given choices for destination directory, format, etc.. good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
greatly appreciate the knowledge guys, thanks.
Just be aware that Exporting the file is just that - exporting the file. There will be no RTAS or Automation applied, no mixing of any kind. For what it's worth, if you wanted the Bit and Sample rate to stay the same, you could just open up the Audio File folder in the session and drag/copy out the files you wanted.
Cheers,
pT 10.3.7 bug: Bounce to MP3 results in delayed audio compared to bounce to wav | Imgoinmad | Pro Tools 10 | 0 | 10-06-2013 12:15 PM |
How can I bounce mutliple audio/instrument tracks as mono Audio files in ProTools LE | thaprof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-16-2008 11:03 AM |
Export Audio Bug | trombino | Pro Tools TDM Systems (Mac) | 0 | 05-02-2006 04:32 PM |
Audio bounce/export/import | LithoJazzoSphere | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-14-2005 03:52 PM |
Why can't I export PT audio like Cubase? Bounce Q | Johnny916 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 07-16-2004 08:46 PM |
