Old 12-12-2017, 09:26 AM
jmattchan jmattchan is offline
Default CTL clutch - fine control interferes with momentary group suspend
We frequently use CTL clutch to momentarily suspend parameters from groups, but it also puts knobs into a very fine resolution mode which makes it pretty much unusable. Can this scheme be changed? It feels like an oversight.
Old 12-12-2017, 01:23 PM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Default Re: CTL clutch - fine control interferes with momentary group suspend
Greetings,
This is not supposed to be the Ctrl modifier - it should be Command for fine operation as it always has been. We will investigate the bug.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-12-2017, 02:18 PM
Thanks Jeff. Specifically was seeing it when testing grouped sends.
Old 08-15-2018, 11:42 AM
Hey Jeff,
Any update on this one? I'm really missing it.
Thanks,
Matt
Old 08-16-2018, 06:53 AM
Investigating this one currently...
It looks like the keyboard function for "Control" behaves correctly when grabbing an encoder just not the chicklet switches on the Fader Modules. This is a workaround in the meantime.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-30-2019, 08:12 AM
I would like to reiterate our facility’s frustration with this issue.
Is it on the list of things to fix?
Temporarily Suspend Track from Group and/ or VCA Automation HansSchumann Pro Tools 11 0 05-08-2015 04:38 AM
MC Control v2 interferes with wireless mouse mtung Artist Series 6 08-27-2014 08:49 AM
PT 9 - Shuttle/Jog Functionality on MC Control jb_trm Artist Series 3 12-04-2010 01:32 PM
7.3.1 cs 5 & group suspend button ! ? priorytools ProControl, Control|24, Command|8 2 10-16-2007 01:59 AM
Suspend Midi track Control data question Vank Pro Tools TDM Systems (Mac) 3 04-03-2007 05:02 PM
