Pro Tools Hardware is either not installed or in use by another program
I had Pro Tools 9 on Windows 7 Ultimate 64 bits with Digidesign 002 rack, working without problems until the other day, while PT9 was opening, I received the message "Pro Tools Harware is either not installed or in use by another program". I did nothing to the computer and it was working with no problems the previous night and in the morning it just happened. The program just doesn´t open.
The 002 works perfectly and sound comes out with the computer sounds and with the music players and also with other Daw's. Nothing seems to be opening on start up and using the hardware and I tried everything I could and the problem remains. Does anyone out there can help me. I'm in the midlle of a work and can't get it to work. Thanks FJ |
Re: Pro Tools Hardware is either not installed or in use by another program
Check your settings in Control Panel-Sound. You probably have your default sound device set to give applications exclusive control.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
i though pt 10 could use anything...why does pt care whats connected!!
i have same error on iMAc bootcamp w64bit |
The error is saying that the interface is being used by another application which in this case could be Windows. You're better off not even trying to use the 002 for Windows sounds IMHO, unless you connect the pc soundcard to the Aux input.
Hey Chris is your focus right interface's still running without a hitch on your window systems??
Yeah, it's running well using the Pro 56 and Pro 40 linked and the Octopre connected via ADAT gives me 24 inputs to Pro Tools. I'm in the process of buying a Tascam 4800 and will probably just keep the 56 with it. Only thing I hate about the Focusrite interfaces is that you have to exit Pro Tools to change the buffer - on pc at least, not on my Mac, plus on the Mac I can get a 32 buffer size!
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB Last edited by cwsand; 04-04-2012 at 09:37 AM. Reason: Felt like it. |
Awesome, I am in the midst of upgrading my hardrives to ones with bigger cache's and tranfer speeds....so hopefully i will be able to run lower buffer settings after i get it ready to go...
pro tools hardware is either not installed or used by another program- can't fix it | drorsh4 | Pro Tools 9 | 11 | 04-25-2017 05:57 PM |
Pro Tools hardware is either not installed or used by another program | kristiankristian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 03-27-2014 07:19 PM |
Pro Tools hardware is either not installed or used by another program | hounddog666 | Windows | 1 | 01-19-2012 05:45 PM |
'Pro Tools hardware is either not installed or used by another program' | thedeeviant1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-19-2009 03:01 PM |
Pro Tools hardware is either not installed or used by another program | kristiankristian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-06-2008 09:54 AM |
