Horrible Build Quality on these units!
I get that the Artist Series is a "Budget Item," but even in that light, one could reasonably expect the fader caps to stay on during use!
8 out of 10 times, when I bank up and down my DAW's mixer, one of the fader caps comes flying off! I keep thinking "what if this happened in front of a client?" NOT GOOD! So, it pains me to ask but, how do you guys get the fader caps to stay on these units? I don't want to try gluing them down, in case they need servicing. So, what kind of options would work on this problem? |
Re: Horrible Build Quality on these units!
I have "flying faders" but not in that way! eBay has some nice replacement caps. I don't think it's your actual fader, so some cheap replacement caps might be nice. I've even replaced them with Presonus ones that feel pretty good. Make sure to get "metalized" or "touch sensitive" caps.
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
All my faders are on tight. Takes a lot of force to pry them off. Did you buy yours Artist series second hand? Are the fader caps physically broken where they attach? Has your unit been dropped in some way (or some else dropped it)?
They were all clean with normal signs of wear and they work as expected. 5 of the fader caps are loose (2 on each mix and fader number 4 on the MC). They don't seem particularly loose to the touch, but clearly they are loose when I'm banking tracks. |
At one point these were put on backwards. All you have to do is reverse them, so the teeth line up with the holes.
I have a bag of Eight Alps fader caps i can ship you.
I will post a pick later tonight
First choose Surface size. Then put in 20 pcs of caps underneath where it says quantity ... that box will be greyed out until you choose size.
Best Regards Christopher #thestruggleisreal ————————————— South Side Music Group WEBHOME ————————————— |
Playback Quality/Horrible | armytanker | Pro Tools 10 | 29 | 12-29-2014 05:46 PM |
How to build a quality home studio on a budget | Joeyjampa | Getting Started | 9 | 09-11-2013 06:54 AM |
Recording quality suddenly horrible? PT8 - files in here. | masta1 | Pro Tools M-Powered (Win) | 7 | 04-03-2009 10:11 AM |
Mixdown quality is horrible | Mad Genius Audio | Pro Tools M-Powered (Win) | 10 | 06-29-2006 06:58 AM |
Horrible, Horrible, Skreeching Noise On Drum Track in Sampletank | William.E.Lemuel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-09-2002 06:54 AM |
