Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 04-13-2013, 11:52 AM
JeppeRask JeppeRask is offline
Default Zoom R16 and PT10
Hi, since Zoom R16 wasnt on the list of hardware that worked with PT10, i tried setting it up manually.
Here, i've set up the 8 inputs - but i can't get any sound in PT10. Does the output and bus have anything to do with it? Could anyone guide me through this? Thanks in advance - Jeppe
Old 04-14-2013, 01:05 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Zoom R16 and PT10
Well, first off, do you know if you are getting any sound into Pro Tools?
If you set a mono track to Input 1 of the Zoom, put it in record enable and pass some audio through the device do you see the meters on the track show any level?
If so, then you probably just need to assign outputs in PT. In the same screen you were in, goto the Output tab and assign outputs. Then, in the track, select an output (typically the stereo pair). Now try recording and see if you get audio when playing back.
Old 04-14-2013, 11:07 PM
Do you mean, set the Zoom to record enable? Cause i'm not sure i can do that, when it's connected via. USB. I will check that when i come home
Old 04-15-2013, 06:05 AM
junkgear's Avatar
Sorry, what I meant was to create a new mono track in PT and select Input 1 as your input source. Put the PT track into record enable and see if you have any input level from the Zoom unit.
Old 04-15-2013, 06:25 AM
JoelG's Avatar
JoelG JoelG is offline
It looks like you have the inputs set ok in Pro Tools, but as Junkgear mentioned, make sure you have each track in Pro Tools set to the appropriate input on the Zoom. Also, you'll want to double check that each track output is set to the Zoom output you have your monitors/headphones on.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 04-15-2013, 06:34 AM
Joel
Yea, that was my thought too - but no matter how i set the output, wouldn't i still be able to see some noise on the 'sound-meter' (dunno what it's called)..
Old 04-15-2013, 09:55 AM
Here is what i've set up:
Output:
Busses:
And the Mixer (they are set to record, but as i screenprinted, the red was off, you know ;-) )
Old 04-17-2013, 07:11 AM
JoelG's Avatar
In the Output tab, change your Audition Paths and Output bus to Output. In the Bus tab, uncheck any busses you don't intend to use (probably all but Output).
Beyond that, everything looks good in your Input tab, and each track, I think.
Have you had any luck?
Joel
Jam Space:
Home:
Rig:
Old 04-19-2013, 01:02 AM
Joel
I tried it, but didnt work out :-/
I also checked that it wasn't Pro Tools, since both my mBox-mini and mBox2 works just fine.. But they're also compatible.
Old 04-24-2013, 12:06 AM
Is it possible to import the settings?
PT10 HD system can't cope with session created in PT10 (LE) LizS Pro Tools 10 19 07-27-2012 03:46 PM
ASIO Driver Zoom H4n not working w PT10 Kinnerfelt Windows 2 07-17-2012 09:59 AM
Lost my Zoom & Zoom preset buttons nwrstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-07-2012 07:28 PM
The zoom/record/zoom back bug... fishkarma 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-19-2010 08:11 AM
Zoom Toggle don't remember horizontal zoom Riccardo Corbari Pro Tools TDM Systems (Mac) 0 01-31-2006 05:30 AM
