Old 08-09-2017, 07:34 AM
bucha bucha is offline
Default Punch Record on a Satellite
Hi guys,
I'm working with two protools in satellite : one for mixing, the other for recording.
I'm looking for a way to punch record in and out in my recorder while staying focused on my mixer on my S6.
This would be very convenient.
Old 08-09-2017, 11:16 AM
creativecontrol's Avatar
Default Re: Punch Record on a Satellite
Greetings,
You can accomplish this in several different ways. Perhaps the best way is with the MPM - Master Post Module which is a PEC Direct paddle interface that supports up to 7.1.2 and can be targeted to any of the workstations in your S6 setup.
You can also use Layouts to bring up groups of channels spanning multiple workstations. You could for example, bring up a layout in a specific Zone on your surface which represents VCA's for your stem recorder that you want to punch into. I would recommend checking out the S6 Operation document 3.6.1 which covers several of these ideas.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-10-2017, 02:26 AM
Thank you very much Jeff.
Sorry, but i don't think i will buy a 5000$ module just for a button that can be targeted to one protools. I'm sure it's pretty useful in many configs but a bit expensive fo my problem.
The solution with one VCA that can punch all the stems and the mix in "Track Punch" Mode is quite interesting but the rec buttons on the faders are too small for the big fingers of a sound engineer …
Wouldn't it be possible to dedicate a soft key (the rec button of the transport section for example …) to a specific worksation ?
Thank you !
Old 08-10-2017, 06:02 AM
Greetings,
It is not currently possible to map a track's record function as a soft key on the transport or to another soft key. Recording can be done from the dedicated record button on a Fader Module's channelstrip, the Master Post Module or the Tracks Page of the Master Touch Module.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-10-2017, 08:14 PM
rcutz rcutz is offline
Thank you !
Colind Broad Pd1 is a pec direct controller at £2.2k I guess.
(Aprox 2.8KUSD)
It has a S6 version. Fader Module Size.
It also alllow stems mute, solo... really nice monitoring features
It works really well. You will need a machine controll license, because it works in the old serial fashion, but it comes with a serial-usb converter.
Allows stems up to 11.1 or something like this (atmos ready)
Colin is very nice and supportative.
Ricardo Cutz
Re-recording mixer/sound editor supervisor.
Http://106db.com.br
Old 08-14-2017, 06:27 AM
Sorry Guys,
i think i didn't expresse myself well.
I was only talking about a single record button (located on the transport panel) that would be dedicated to my recorder satellite to punch in and out my sequences without switching between workstations …
My workaround is to use a fader port connected to the recorder.
So the idea was simply to be able to dedicate a soft key to a specific workstation.
Thanks.
Old 08-14-2017, 08:49 PM
EddieJones's Avatar
You could lock the transport section to the recorder and focus the rest of the console to the other WS.
Old 08-16-2017, 01:27 AM
Thank you very much Eddie !
It works perfectly !
Record sync with Satellite? IO Composer Pro Tools TDM Systems (Mac) 1 04-29-2009 01:18 PM
no punch in record scrconstruct 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-26-2008 07:23 PM
Record Punch Problem: Hear old take/Record new take Felix Rost Pro Tools TDM Systems (Mac) 5 01-04-2008 11:29 AM
punch record Studio Forte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-12-2005 05:42 AM
PT not going into record at punch in using hui!? Boom Chic Pro Tools TDM Systems (Mac) 8 11-17-2001 08:15 PM
