Old 11-13-2021, 10:00 AM
machambers machambers is offline
Default 11R Editor & Win 10 Pro x64 20H2
Has anyone successfully installed the Editor on a Windows 10 Pro x64 v20H2 machine?
I had it running on a Win 10 Home x64 v1906 machine, but it suffered a motherboard failure.
My attempt at installing it on the new machine resulted in a BSOD and then boot failures. After a bunch of work I got the machine stable again. The 11R driver is installed and the machine recognises it. Needless to say I'm more than a little gun-shy about re-trying the Editor installation.
If you were able to install the Editor to this particular OS, did you have to do anything special?
Thanks
Old 11-13-2021, 11:00 AM
universengc universengc is offline
Default Re: 11R Editor & Win 10 Pro x64 20H2
1. Download installer.
2. Start setup
3. When program ask for reboot, just close, dont reebot pc.
4. Go to ilok site and download installer ilok and install it. https://www.ilok.com/
5. Reebot
6. One more time start editor setup and install editor.
7. Done.
Old 11-14-2021, 10:14 AM
It worked like a charm, thank you for your help.
I will note that I also cleaned out duplicated Eleven Rack and Eleven Rack DFU entries, including the hidden ones, from control panel before starting.
Windows 10 20h2 - digi 002 rack - pt12.7 super guide! Roberto Tafuro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-21-2022 03:09 PM
Windows 10 20h2 not yet supported, but does it work? akumraza Pro Tools | Intro Discussion 3 03-24-2021 12:04 PM
Win 10 version 20H2 taylor4814 Pro Tools 2020 5 02-09-2021 08:01 AM
Windows 10 Build 20H2 Crashes After Installing Digi 002 and 003 Drivers v9.0.2.65 Knobtweaker_Flagtown 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-06-2020 06:42 PM
MIDI Editor and MIDI Event Editor keyboard commands broken 12.4 HD Marsdy Pro Tools 12 5 01-31-2016 05:01 AM
