#981
Re: Best Core 2 Series Desktops-Results and Specs
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#982
Question for all Q6600 owners....
What temperature does your CPU idle at, and under load? What cooler are you using? I've finished building my machine and I was about to do a D-Verb test. (I'll post the specs of my build at a later date.) In my bios there is an option to have an alarm beep when the cpu gets too hot. I have mine set to 60deg C. Just to be safe for now. No OC'ng just yet. While in my BIOS i noticed that my CPU idles at around 48-51 C. I try to do a Dverb test, and of course it starts to heat up and the bios alarm goes off 1/2 way thru the test. I check my temps and according to SandraSoft I'm up to 71C.... So Could my stock cooler be broken? it's running at about 1,400-1,500 RPM. it is quiet. Also on the box and CPU it says SLACR. CPU-Z shows the CpU as a 6FB revision G0. SandraSoft says SiSoftware Sandra Processor Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Speed : 2.40GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Bus : Intel AGTL+ Package : FC LGA (Socket T) Rated Speed/FSB : 2.40GHz / 4x 267MHz Multiplier : 9/1x Minimum/Maximum Multiplier : 6/1x - 9/1x Generation : G8 Name : C2QX (Kentsfield) Core 2 Quad 65nm 2.0-3.33GHz 1.0375-1.3V Revision/Stepping : F / B (0) Stepping Mask : G0 Microcode : MU060F0BB6 Core Voltage Rating : 1.325V Min/Max Core Voltage : 0.825V - 1.325V Maximum Physical / Virtual Addressing : 36-bit / 48-bit Native Page Size : 4kB Co-Processor (FPU) Speed : 2.40GHz Type : Built-in Revision/Stepping : F / B (0) Power Rating(s) CPU Core Power : 93.15W CPU Cooling System Thermal Resistance : 0.26°C/W Sensors CPU Temperature : 58.00°C td <----------------!!!!!!!!!!!!!!! IDLE!!! CPU DC Line : 1.28V I have a G0 correct? I'd just like to make sure. Anynody using a good cooler besides the stock Intel, or Zalman cnps 9500. I have 2 Zalmans in my AMD machine and I'd actually like something not so loud if possible. Thanks all!!! Dennis |
#983
yep, you've got the G0 stepping my friend. you could choose to lower your CORE VOLTAGE. you are runnin' it at the max rating now according to SANDRA. your cpu box should have the rating on it. i'm actually runnin' mine lower than what the box has on it. i think i'm runnin' 1.15v and believe me you'll see the temp drop if you lower the voltage this is the cooler i'm using...
FREEZER 7 PRO dropped my temps about 10 degrees on idle. much better ones out there i'm sure. but i liked the price and reviews
#984
Hi, I have a X38 Maximus Formula and I Happy!! for this desition. FW port its ok whit PT 002 R And in a OC responds whitout problems. Thats the way! Sorry i cant be more extensive because my english is "mini" Sorry On the pages 36 to 38 you can see my post whith the same cuestions and the answers from the crew. Bladesg is other Maximus Happy User and put light over my way.. Good Luck! POL |
#985
Mykhal, Thanks again for your speedy and helpful response!! I was looking at the same fan. great price! Is it quiet? I adjusted my CPU voltage to 1.15 and that lowered my temps! Thank you. I was able to perform a Dverb test without the system alarm going off. Kind of strange though... Sandra, and SpeedFan listed the cpu well over 60C which is what the alarm is set to. 71 C at load according to Sandra. The alarm is controlled by the BIOS so I'm guessing that there must be a little inaccuracy in the software... So with no XP tweaks, network still enabled, and without OC'ing, my system gave 250 Dverbs. And that's with 4GB of 800Mhz DDR2 Mushkin RAM. The timings were set by the BIOS on auto. 5-5-5-18 which is terrible. But I wanted to see what kind of difference there would be once I set to the RAMs proper timing and voltage. The RAM is spec'd to operate at 800Mhz 4-4-4-12, at 1.9V which is why I chose this RAM. The voltage is much lower than most for those latency timings. Most of the other RAM was rated at 2.0V and up. This RAM stays nice and cool. After I adjusted the timings properly, I saw a 13 dverb increase for a total of 263!!! So I'm pretty happy! Thanks for your help Mykhal!! I'll post my system specs a little later... -Dennis *** I should note that page filing is disbled. |
#986
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#987
Check out CPUz for the best timing referances and at the same site you can download "Hardware Moniter" which gives me the same temps as Core Temp. All are simple Exe files that need no installation. Missed you on Skype last night-check with MattP for a little good news
#988
thought i'd bring a couple of free tools over to this thread from another. these 2 tools deal with identifying latency on PC's.
1) DPC Latency Tool DIGI posted this initially. shows system's latency in millisecs. easy install. i actually checked my quad out while recordin' at 64 buffer. 2) RATTV3 Developers Tool very detailed tool that logs detailed info on drivers latency for developers. DUC'er TCM brought this to the other thread. another great tool!!! highly recommend them both!!!
#989
I have been reading this thread a couple of times now, absolutely the best thread for building a Pc for protools (bang for the buck). Big thanks to sunburst, mykhal and bladesq!!
Here is a pc I have found for sale used, it looks cool. I am curious-will this machine run protools le 002 rack; Asus P5K PREMIUM/WIFI-AP Black Pearl 775 Intel Core 2 Quad Q6600 Mist, 600W FOX+ GeForce 8800GT 512MB PCI Express 2 Lian Li Miditower 1 x Western Digital Raptor X 150GB S-ATA 16MB cache 10000RPM 1 x Samsung 500 GB 7200RPM S-ATA2 I think the MOBO will work, I have read that samsung harddrives can be tricky. And I am not sure if the graphic card will work. Exuse my english, being norwegian. |
#990
i7 Builds - Specs and Results | mykhal c | Windows | 7144 | 04-15-2024 12:10 PM |
Intel Quad Core vs. i-series | solidwalnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-23-2010 05:16 AM |
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-12-2009 02:24 AM |
are these specs ok? (low budget 2 core) | korkman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-22-2008 02:44 AM |
8 Core Mac Pro, Leopard and Windows results | pasanta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-13-2008 06:51 PM |
