Track counts
I just installed my MBox and PTLE6.4 onto my laptop. Ran the davec test and it came out with a count of 22, which I think is well low considering my laptop spec and settings. I am using:
P4 2.6GHz 865PE MOBO 1GB RAM ATI 9600 Mobility 128MB External LACIE 160GB FW drive I have minimal services setup - about 11 running. Visuals optimised for performance Page file set to 1536 (1.5 times my RAM) on a seperate Page File partition. Processor scheduling set to Background services H-T turned off. Most of the tweaks as laid out on tweakhound, music-xp and blkviper websites. Network adapters, floppy disks, modem, other sound card all disabled. Max CPU usage set to 85%. HW Buffer setp to 1024 samples, playback buffer set to level 2. My computer seems quite slow to start-up as well, with the userinit and other initial services taking ages to turn themselves off. Also when I move the mouse in protools the CPU meter jumps around quite disturbingly. Does anyone have any ideas why my system is not performing too well? I really don't want to reinstall windows and start again cos it takes me nearly a day to edit the services, and do all the performacne tweaks and reinstall all my music software?? Please help!!! |
Re: Track counts
Set your waveforms to blocks in your edit window and run your graphics at 16bit.
Remove the mouse and use the touchpad or a dedicated mouse port (not usb) Turn off unused I/O. |
Re: Track counts
My mouse is PS2 so no problem there.
What do you mean turn off unused I/O?? Is this track count normal for such a system or am I missing something?? |
Mix+ track Counts? | jimmyz | Pro Tools TDM Systems (Mac) | 6 | 05-08-2009 05:11 PM |
Track counts | mix_master_adam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-20-2006 06:57 PM |
mix 24 track counts | acappellaj | Pro Tools TDM Systems (Mac) | 3 | 11-08-2005 11:31 AM |
Track Counts? | B3nzdigi | Tips & Tricks | 16 | 11-05-2004 07:35 AM |
Want to go MAC....track counts? | HL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-10-2001 08:32 PM |
