Arming Channel Record Button on Protools LE
Hello
I have a big problem and it is something which gives me hard time . Is it possible to arm "rec" on audio or midi channel while the PT LE in playback mode ? So far i couldn't manage it . I have to always stop the sequence to do that . But when i am stopping the sequence, i am loosing some random grooves happening while i am jamming with the units in my studio . All i want to achieve is , to be able to arm Record of any channel while PT LE is in playback mode without stopping . I know there is also "Quick Punch" option , than in this case you have to arm the record button of the channels in advance . But this is also not useful for me . Any ideas ? |
Re: Arming Channel Record Button on Protools LE
Quick punch is the only option as far as I know.
If you have a mixing desk, you could run all your units through it and send each channel out on aux 1 so that you could have aux 1 of the desk sent to a single input of Protools. You can arm record a track for this channel and jam away and when you get a random groove you like you could quick punch record and whatever unit you're playing will be going through the aux into protools.
From the manual
MIDI and Instrument tracks can be recordenabled during playback or record. To record enable audio tracks, the Transport must be stopped, or QuickPunch, Track- Punch, or DestructivePunch must be enabled. For more information on Quick- Punch, TrackPunch, and DestructivePunch, see “Record Modes” on page 353.
MBox2Pro / LE 8.0.5 |
is it same when you have Protools HD ?
Still it cannot be armed in playback ? |
if its an audio track you are referring too, the mode is called track punch. its only available in HD.
On le, you can arm midi and/or instrument track while playing back, not audio tracks.
my blog:Tamas Dragon |
awful sound when arming track for record | BenDorigan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-09-2012 10:01 AM |
Record 1 audio track, then go to record a second, the timer button flashes... help | tdubthatsme | General Discussion | 5 | 02-27-2011 04:39 PM |
Master Record button doesn't record arm MIDI tracks? | Borg | ICON & C|24 | 1 | 10-29-2007 07:39 AM |
monitoring without arming record | Allen Tucker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-03-2005 01:43 PM |
