Old 08-11-2017, 03:01 PM
KMcK KMcK is offline
Default 12.8 Workspace & Waveforms
Ongoing bug, still not fixed in 12.8 apparently.
Workspace windows stop responding to "Calculate Waveforms." The task is selected, Task Manager Window shows progress bar... but no waveforms appear in the workspace window. This occurs even in folders where I have previously calculated and had waveforms visible, but they are now failing to show.
This seems to get consistently worse as I get further into any project. Initially things are fine, a week or two in they start to go wonky, and by a month later I can't get any waveforms at all.
Anyone found a solution to this? Makes the workspace pretty much unusable after a while. I've been dealing with this for years, not sure when it exactly started. I have 2 PTHD rigs (currently both with 12.8), both have this problem.
http://www.imdb.com/name/nm2384808/
Old 08-11-2017, 04:32 PM
john1192 john1192 is offline
Default Re: 12.8 Workspace & Waveforms
Non-HD .. just tried it here on a bunch of files .. as long as i highlight the files that i need to Calculate Waveforms it works fine ... or as soon as i click on a File it creates the Waveform if it is empty before i click on it ..
are you on Mac or PC ??
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 08-11-2017, 04:46 PM
Both my rigs are Mac, 10.12.6, just slightly different hardware. They mirror each other with drives and software though. I take an iLok back and forth depending on where I'm working so I basically have it set up so that they behave almost identically.
I just got back to my studio rig which is a 2013 trash can and it's behaving better than my work rig which is a 2010 upgraded cheese grater. I posted earlier from work on the cheese grater which had just stopped making waveforms all together today. I've seen this behavior before though, and stretching back a while, but could be wrong that the trash can has seen it recently.
If it could somehow be related to graphics card then that's probably the culprit. The cheese grater needs an upgrade in that department.
Waveforms in workspace disappear when I click on folders chefbrody Pro Tools 12 1 10-26-2016 02:28 AM
workspace missing waveforms simplex Pro Tools 12 0 10-26-2016 02:24 AM
Calculate waveforms in workspace? dkrz Pro Tools 11 3 06-12-2015 09:16 AM
Can't calculate waveforms in workspace.Help. dacapo Pro Tools TDM Systems (Mac) 9 11-29-2007 05:06 PM
Problems with workspace waveforms! Please help!!! arturix Pro Tools TDM Systems (Mac) 5 08-03-2007 02:17 AM
