Old 08-22-2015, 11:56 AM
DavidHeylen DavidHeylen is offline
Default video freezing
Hello,
My video freezes up in random places when I'm in play. When I stop and play again it's solved.
I just installed HD12(empty bankaccount), running PT 11 before this and it worked fine.
Only now I'm running Yosemite.
I tried Motion Jpeg and DNxHD convert via MpegStreamclip but problem remains.
I need a solution fast because my first project in my home setup is coming up in september.
Greetings,
David
www.literecordings.be
Old 08-22-2015, 02:15 PM
ArKay99 ArKay99 is offline
Default Re: video freezing
Originally Posted by DavidHeylen View Post
Hello,
Greetings,
David
I'm about to embark on a similar endeavor. Running PT12.1HD on a MacPro 6.1 Thunderbolt on Yosemite. I hope I can get it to work. One thing I read about was the importance of having your video files on a dedicated or at least a separate fast drive from the system and audio.
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2.
Old 08-22-2015, 07:30 PM
KMcK KMcK is offline
Hello,
Greetings,
David
What are your system specs? Does it happen in the video window, external monitor, or both? I use several different codecs (DNxHD, ProRes, H264) in PT12 on Yosemite with a thunderbolt Blackmagic Intensity and don't have any issues.
http://www.imdb.com/name/nm2384808/
Old 08-23-2015, 09:31 AM
I'm gonna try a faster disk for my video's. Don't use Blackmagic cards.
The thing is that it use to work fine with my early PT11 setup. I mixed a whole realityshow season with it.
Thanks for the tips !
Old 08-25-2015, 12:06 AM
Ophir_Lokay Ophir_Lokay is offline
Default Protool 12HD and Blackmagic
Hello
I am a post production sound editor. Works on mac, PT-12HD and Blackmagic Video card.
I have some freezing video problems.
Q_time DV pal, mp-4
I have a ssd hard disc, special for video files.
anyone can help?
Is a Graphic card with 4 outputs will help?
( a screen to edit, a screen to the mixer and plugins, and a TV for the movie)
Old 08-25-2015, 12:24 AM
I have the same problem, working with blackmagic card.
The sollution, maybe, is to use g_Card with 4 outputs, and plug your TV to one of them.
The best is to use Q_time DV pal, or MXF files.
Movie/Video Playback Stopping/Freezing Multiguy Pro Tools 12 6 08-09-2015 07:48 PM
Video Freezing while editing then PT 10.3.6/PT 10.3.7 crashes Imgoinmad Post - Surround - Video 11 09-22-2013 11:17 AM
Pro tools SLOW, and Freezing then continuing, then freezing again DJX-RAY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-09-2011 07:52 AM
Video freezing 1/10s when I punch record? johnbob Pro Tools TDM Systems (Mac) 0 08-04-2003 10:45 AM
Freezing when working with Audio and Video Alagu Pro Tools TDM Systems (Mac) 0 08-01-2003 06:19 AM
