Old 08-01-2015, 06:48 AM
diabolusinmusica diabolusinmusica is offline
Default Tempo change not working! - Please, please help!
Hi!
I've imported an audio file into Pro Tools, converting it from MP3 to a Pro Tools file. Now I need to make several tempo changes. I've activated Elastic Audio, activated conductor track, set the track to polyphonic (it's a piano track), and I've put in my markers, expanded the Tempo bar, pencilled in all the lines and moved the green line to the correct tempo, etc. But nothing happens! The tempo remains the same throughout! I've tried everything! I've tried manually keying in the tempo changes, and nothing works.
The track/waves don't expand with the lines when slowed down, nor does it shrink with the transient lines when speeded up. The lines move, and the track/waves remain still. It just sits there whilst the lines move.
Please help! Is there something I've missed or not activated?
Old 08-01-2015, 08:09 AM
KMcK KMcK is offline
Default Re: Tempo change not working! - Please, please help!
Is the track in tick mode or sample mode? You want tick mode.
http://www.imdb.com/name/nm2384808/
Old 08-02-2015, 04:50 AM
Sorted it! Turns out I hadn't changed it from sample mode to tick mode. :) Thanks!!
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
Need to Change tempo but without changing existing midi data tempo? Einsteinwannabe Pro Tools M-Powered (Mac) 2 09-18-2010 06:58 AM
Ramping a Tempo Change (interpolation or discrete tempo points) edgarbc1 Tips & Tricks 3 02-18-2009 12:55 PM
Tempo Change w/out moving other tempo changes pietro79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-20-2006 09:00 AM
Tempo change without pitch change for audio layman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-16-2002 07:14 PM
