Old 12-17-2020, 05:06 AM
JpTracks JpTracks is offline
Default Zoom features
I recently switched from Cubase 10.5 to Protools 2020. In cubase I could hold control+ scoll and zoom in exactly where the cursor was. If I hovered the cursor over the beat control+ scoll and it would zoom in. Is there a way to apply this to protools WITHOUT HAVING TO CLICK ON THE ZOOM TOOL? If not, is there at least a way to zoom in to a selection while recording or play back? I like to edit as I'm recording an artist sometimes and zooming to editing a part in the middle of the song while recording at the end would be so helpful. HELP
Old 12-17-2020, 12:35 PM
Default Re: Zoom features
Hmmm, that can be a dangerous work flow. When I am recording, I try to do nothing else. Many times, things work just fine, but accidentally hitting the wrong thing can ruin a take, whether it stops recording, or causes some little change to the headphone mix that the artist(s) are working to.
Having said that, there are a few things to try:
1-If you highlight a selection and hit the E key(keyboard focus enabled), the selection should fill the screen almost completely
2-You have scrolling options to consider(Options menu>Scrolling) so check them out. I like to use the PAGE setting, but you might prefer NONE(the default).
3-The T and R keys will zoom in and out horizontally
BTW, keyboard focus is turned on/off on the little box(upper right corner of the edit field) with the az letters(yellow is on). This allows most key commands to work without also using the Ctrl(Cmd) key, so check that stuff out too
Old 12-17-2020, 04:54 PM
The Weed's Avatar
The Weed The Weed is offline
Have a tour through the Pro Tools Shortcuts PDF. Look for Alt+Scroll, Shift+Scroll and Alt+Shift+Scroll. I use these a lot.
Look in the Reference Manual for "Scrolling Options" and "Linking or Unlinking Timeline
and Edit Selections". I'm not sure if you can edit while recording, certainly not in Shuffle Mode, but you would have to UNlink Timeline and Edit Selections to try. You can also "drop in" Markers where you want to make an edit after recording, but be sure to set the Preference to automatically name memory locations.
As albee said, I too wouldn't be doing any editing when recording.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-20-2020, 11:50 PM
Kerochan Kerochan is offline
Learning Pro Tools on 12.5 here, the zoom features are not as good Logic, I reckon, or maybe its coz I am so used to Logic?
Though I do like the fact in PT you can click on the numbers 1,2,3,4,5 for different zoom presets, thats great.
Old 12-21-2020, 11:02 AM
The Weed's Avatar
"Have a tour through the Pro Tools Shortcuts PDF. Look for Alt+Scroll, Shift+Scroll and Alt+Shift+Scroll. I use these a lot."
SonoBus
Zoom In R, Zoom out T. With unwanted ctrl lamacchiacosta Getting Started 2 01-24-2020 01:54 AM
Zoom Presets and Vertical Zoom Inconsistent matthewmkb Pro Tools 2018 0 04-16-2019 06:20 AM
Lost my Zoom & Zoom preset buttons nwrstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-07-2012 07:28 PM
The zoom/record/zoom back bug... fishkarma 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-19-2010 08:11 AM
Zoom Toggle don't remember horizontal zoom Riccardo Corbari Pro Tools TDM Systems (Mac) 0 01-31-2006 05:30 AM
