Old 04-24-2020, 03:00 PM
DLSilsbury DLSilsbury is offline
Default Only on board mic showing
Hi, I'm a complete novice at this type of software. So I'm using Pro Tools First, and have an old mic SoundPro something or other from maplin. The computer recognizes it as 2-c-media audio device. It's a USB mic. However Pro Tools First doesn't display it as an option when I try to change it in the playback engine.
Old 04-24-2020, 03:19 PM
Default Re: Only on board mic showing
Does the mic have an available ASIO driver(Windows) or Core Audio driver(Mac)? ASIO4ALL is a freeware ASIO driver for Windows that may work. For PT to work with it, it must be available and selected to be the "audio engine" in PT. Check youtube for some tutorials on getting started with pro tools.
Old 04-25-2020, 04:22 AM
Thanks for the quick response. I installed ASIO, I don't know what I'm doing with it though so I'll look up some YouTube. I have some questions regarding why it shows as out as well as in?
Not sure how to add a picture, which would have helped.
EDIT: I may have just added the screen shot as an attachment
Old 04-25-2020, 04:58 PM
"why it shows as out as well as in?"
Not exactly sure what you mean, but Pro Tools can only use a single device(aka "audio engine") so inputs and outputs must go thru the same device
Old 06-04-2020, 02:29 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Most USB mics have a headphone jack so you can monitor while you're recording... ProTools is seeing it as an interface, which it is.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Any one using this board please Raoul23 Pro Tools TDM Systems (Win) 1 12-15-2010 04:47 AM
Looking for a new board. Spyrojoe Tips & Tricks 3 02-23-2007 10:07 AM
BOARD TECH NEEDED to service Amek Matchless board audio[LAB] General Discussion 4 01-31-2007 11:17 AM
On Board DSP? EarnestBliss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-18-2002 11:29 AM
Sound cDev not showing AMIII board? dylennon General Discussion 3 07-03-1999 12:34 AM
