Old 12-23-2013, 09:34 PM
justus1900 justus1900 is offline
Default Pro Tools 11.1.0 AAE-9173 Error
Installed Pro Tools 11.1.0 and now none of my older sessions will play, As soon as the session loads my CPU Meter goes to 100% no matter what buffer rate. These are sessions that would play at 64 buffer rate in PT11.0.2 will not play at all? Any else having this issue after this PT 11.1.0 update?
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell Precision T1500 Minitower
OS: Windows 10 SP1
CPU: Intel® Core™ i7-860 (2.8GHz,8MB)*
Memory: 32GB (4 X 8GB)
SATA Internal OS 480GB SSD, Record 480GB SSD, 1TB and 750GB External Glyph GT 050Q 500GB HD
AVID Digi 003 Console x 2
AVID Pro Tools 2019.12
JBL LSR4328P Studio Monitors
Yamaha HS50M Studio Monitors
Portable:
Model: Acer Aspire E5-575
OS: Windows 10 Home 64 Bit SP1
CPU: Intel® Core™ i5-6200U
Memory: 16GB
SanDisk 256GB SSD, 480GB SSD
AVID: Fast Track C400
Pro Tools 12.5.0
Old 12-23-2013, 09:52 PM
Default Re: Pro Tools 11.1.0 AAE-9173 Error
Restarted sessions with "Shift" button hit and started "Make Active" on my Plug-Ins one by one and its the "AVID MasterMeter" that is making my CPU Spike to 100%. Once I removed that from my sessions they all play fine now. So there is some kind of bug in the AVID MasterMeter in Pro Tools 11.1.0.
Main:
OS: Windows 10 SP1
Portable:
Memory: 16GB
Pro Tools 12.5.0
Old 07-01-2014, 01:51 AM
FLi's Avatar
FLi FLi is offline
Had the same issue but I find its with the SansAmp-PSA plug. It works for a bit and then it just goes mad and chews up CPU. Disable it and everything runs smoothly again.
Old 07-01-2014, 04:59 AM
Pro Tools 11.2 MasterMeter no longer causes CPU usage spikes. (PTSW-193401), Bug Fixed, Thank you
Main:
OS: Windows 10 SP1
Portable:
Memory: 16GB
Pro Tools 12.5.0
Old 12-22-2015, 02:46 PM
TeeMade TeeMade is offline
Default Re: Pro Tools 12.3.1 AAE-9173 Error
ERROR STILL POPPING UP ALL I USE IS NATIVE INSTRUMENTS SMH and i have HD its happened 4 times in a session which is an improvement never the less a big situation as far as performance hd is suppose to be at prime performance PLEASE FIX
AAE - 9173 cpu overloads in pt11 vs pt10 Carbon 2501 Pro Tools 11 0 03-07-2014 09:22 PM
Aae-9173 txrx Pro Tools 11 5 12-28-2013 04:34 PM
i7 Macbook Pro - 11.0.2 / 11.0.3 constant -9173 errors A Chapman macOS 13 12-18-2013 09:36 PM
Pro Tools 8: Activation code not working/Error: Data Error (cyclic redundancy check) Mattmattmatty Windows 2 05-01-2013 04:26 AM
H/W Buffer Error (pro tools error -6104) Only 1 audio track running. kieran.mia macOS 1 01-29-2013 01:39 AM
